Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Oh God what now!!?
So im driving to the local Midas to have a new tip welded on and my cars started stalling out at a stop light. It did start again and does stay running with foot on the gas. I was able to get it to the Midas and told the guy to go ahead and checkout what the issue may be. He had $ signs in his eyes and a nice big smile.
i glanced under the hood. Didnt see any tubes or hoses off. no water leak. Started up again and stalled out. ideas?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 09-12-2008, 09:54 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Not a whole lot to go on there...Big vacuum leak comes to mind, but you checked the hoses and such...Check again mayby a tube fell out of a plenum or something. Sometimes the big rubber tubes crack and it acts just like that. Smoke test the running engine (requires a smoker)
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 09-12-2008, 10:17 AM
Greasy Member
many944s's Avatar
When it does run, is it running rough? I had a similar problem when one of my injectors got clogged up. It would start, then stall. But If I held the gas, it would run on 3 cylinders. I ended up replacing the injectors, but in the process found TONS of crap in the fuel rail. A full flush, and a new fuel filter later, no problems.
Hope it helps!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Rockin' NW Arkansas
well it has always ran a bit rough, but yes now rougher. no warning at all. i did notice lastnight that it had less power in 2nd gear when i was..... driving along like a little old lady along side a 82' vett. this morning i drove over to the car was and rinsed it off then went about 6 miles. that last 10th of a mile was when it started poopin out.
Matt
Old 09-12-2008, 11:28 AM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Dis you power wash the engine too? Or just the outside?
Sounds like you have a vac. leak and have had one for some time. And now that you washed it, water has gotten in and worked it's way into the fuel. Can give it a day to let it evaporate out on it's own, or just run the car for about an hour and see if it helps.
But I bet one of your big hoses is cracked, broken or not hooked up.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 09-12-2008, 11:40 AM
Rockin' NW Arkansas
no just rinsed off the exterior. what is this big hose that i keep hearing about?
Matt
Old 09-12-2008, 11:47 AM
earlr85944's Avatar
check the j boot and afm conncetor very well.
get a friend to keep it running and spray starter fluid at suspected connections to see if you have any leaks
next throw a pressure gauge on the fuel rail to see if all is well there
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 09-12-2008, 12:20 PM
Open the hood and start looking. not hard to miss the hoses.
I wouldn't have a muffler shop do anything with it though, just asking for trouble there.
86 Metallic Grey
Old 09-12-2008, 01:08 PM
Rockin' NW Arkansas
ok, i went back to the shop with your suggestions. they said it was "building up" fuel and was getting some bad black smoke. smells very rich. injectors were clicking. they spayed some crap all around the engine looking for vac leaks and didnt see anything. then i told them where i got gas last and everyone in the shop went "ooooooh". apperently with all our rain they have been getting customers who have been towed from that same station last week. 1 lady had 1/4 take of water. they put some crap in my fuel and the car runs better but still have alot of smoke. he told me to drive that last 1/8 of a tank out and to never go there again. did say i need all exaust from the header to the tip.
Matt
Old 09-12-2008, 02:40 PM
Well of course they did! they are an exhaust shop.
I dont think you need emission tests though on yours so I wouldn't worry about it till there is a big gaping hole in it
86 Metallic Grey
Old 09-12-2008, 02:53 PM
Rockin' NW Arkansas
lol
Oh these folks are cool. 3 of the guys are also Firefighters on my dept.
I also say "Midas" alot on the radio. They spent 2 or 3 hours on my car today and didnt charge me a penny.
Matt
Old 09-12-2008, 03:45 PM
Toofah King Bad
Rasta Monsta's Avatar
I thought 944 exhausts were SS??
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-13-2008, 08:13 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
the catback pipe is, as is the cat itself, and i believe the exhaust manifolds are (at least on the late cars. early were cast iron). the cat pipe tubing (from flanges to cat, and cat to catback pipe are not stainless.
other than the cat section of the pipe, and possibly a new muffler (old one clogged/restrictive), i'm not certain what exactly you would need replaced.
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 09-13-2008, 08:32 AM
earlr85944's Avatar
the 944 muffler is also stainless
83 944....bye bye
Old 09-13-2008, 08:56 AM
Exhaust isn't SS. If it was it wouldn't rust. Have you ever seen a muffler or cat that wasn't rusted on these cars.
86 Metallic Grey
Old 09-13-2008, 10:20 AM
earlr85944's Avatar
check again, if it wasnt stainless I wouldnt have the original exhaust on my 23 year old car
83 944....bye bye
Old 09-13-2008, 11:04 AM
The exhaust is stainless. There are different stainless grades. That is why you see a little rust on the system.
Old 09-13-2008, 12:11 PM
earlr85944's Avatar
yes, what you are seeing is surface contamination
83 944....bye bye
Old 09-13-2008, 12:57 PM
Rockin' NW Arkansas
if it helps, they said my pipe was ok. muffler was "smashed" as if the car bottomed out on something at one time. the cat could be ok, but said it wouldnt hurt to replaceas well. the worst was were the pipe connects and also the gaskets at the header could use a replacing.
Matt
Old 09-13-2008, 03:24 PM
Do you need emission tests?
If not, just remove the cat and go with a straight pipe to the muffler.
You can do the gaskets yourself, they are easy as long as they aren't rusted on.
86 Metallic Grey
Old 09-13-2008, 08:54 PM
