Greasy Member
many944s's Avatar
What you DONT want your head gasket to look like!
I thought I was going to be lucky enough to have a slow week and work on my to-do list at the shop... HA.
Anyway, I had a local 924S driver bring his car in after finding out I run a shop. He stated that his car was overheating ALOT, and the overflow tank had turned kinda brown Long story short... Check out this head gasket
Not alot of fun!
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 09-19-2008, 11:05 AM
unindicted co-conspirator
looneybin's Avatar
at least it looks like it still had good compression
'03 996 - sport exhaust, sport seats, M030 sport suspension, stability control, IMS Solution
‘86 928S3 - barn find project car
Old 09-19-2008, 11:25 AM
AKCJ's Avatar
Makes a guy wonder is we shouldn't get in there and retorqe the 25 year old head? Or, maybe this is caused by something else? Or it's just old age.
Red 83 944
Old 09-19-2008, 12:22 PM
looks like coolant and fuel has just eaten away at it for 10 years, my headgasket looked bad but not nearly that bad, and it had milkshake everywhere for who knows how many years before i got it.
1987 944 n/a
Old 09-19-2008, 12:35 PM
Trying to work for parts!
Send a message via Yahoo to hpservertech
Just another perfect reason why I'm going to go ahead and replace mine over the winter...before it goes south.
86 Metallic Grey
85.5 Metallic graphite - Gone
Old 09-19-2008, 12:42 PM
Toofah King Bad
Rasta Monsta's Avatar
Could be a manufacturing defect. An odd percentage of 87 924S models lose head gaskets at 75-100k miles.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 09-19-2008, 01:45 PM
That Guy
Techno Duck's Avatar
The words of Adam Savage : "Well there's your problem"
I think alot of it is the headgaskets just start breaking down after 20 something years being submerged in coolant and being subject to heat cycles. Its a pretty harsh environment. What did the deck of the cylinder head look like? Any major pitting in the aluminum? I wouldnt be surprised if the wrong coolant was being used also.. phosphate free antifreeze is important!
My headgasket let go after about 100k miles on my n/a. The fiber material broke down and water pushed past, and split the fire seal ring in two, allowing coolant to enter the cylinders.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 09-19-2008, 02:59 PM
flash968's Avatar
we are starting to see head gaskets deteriorating on the 968s - they are falling apart - not blowing, just disintegrating
a little unsettling to say the least - i never thought of a head gasket as a preventative maintenance item
Old 09-19-2008, 03:06 PM
Greasy Member
many944s's Avatar
I thought there would be a lot of pitting as well, however there wasn't any. There wasn't even any of the head beginning to corrode!
I can't say the same about the water pump, whose impeller wasn't doing much of anything since most of the vanes were gone. The fire rings were still doing their jobs at least. I think I am going to have to lean toward the "manufacturing flaw" or old age. And fyi, it was an original non "turbo" head gasket.
Old 09-19-2008, 05:03 PM
bland vanilla's Avatar
It doesn't look that bad. JC Whitney has a repair kit for it that also adds 100 HP.
00 Durango
98M3
01 ML55
Old 09-20-2008, 05:38 AM
meister member
speedracing944's Avatar
mine was not as bad but i was surprised at how much it was deteriorated.
speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 09-20-2008, 06:00 AM
One apex at a time
Dean924s's Avatar
Yiks. And yes I have seen several 87 924's with head gasket problems. I am wondering if they used old stock for those like they did with so much of the rest of the 87 924s.
I keep thinking that Mr Porsche must have been having a pint with the bean counters and they told him to get rid of all the old 924 and pre 85.5 944 stock they had in some warehouse some place. The 88 924s was just a case of they forgot to stop production ,
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 09-25-2008, 07:19 PM
Schumi's Avatar
That's pretty much the 924S story- they were losing sales, the 959 was running their profits into the ground... and they had a bunch of early components from the 924's and series 1 944's laying around. Thus a new model was born...
M
Old 09-25-2008, 07:32 PM
thekidd's Avatar
Send a message via AIM to thekidd
Pshhh. Is that the old head gasket, or the new one? You could fix that with a little super glue and your good to go track it. Or the other solution, Duck tape. That looks gross, but an interesting picture.
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 09-25-2008, 09:36 PM
Proprietoristicly Refined
John_AZ's Avatar
Anyway, I had a local 924S driver bring his car in after finding out I run a shop. He stated that his car was overheating ALOT, and the overflow tank had turned kinda brown. Not alot of fun!
Lets add this up.
Head gasket set, many944s reconditioned head, water pump, front seals, complete block and cooling system flush, chemicals, cracked hoses and a ton of WYAT stuff, tuneup and finally shop fees, labor and tax.
Then add all the other lack of maintenance seen by the shop for future work.
PRICELESS
Now about the crack that Porsche had a warehouse full of spare parts and built the 1988 924S....yup, but I'm happy.
John_AZ
1988 924S 58K to Show
1987 924S 112K DD to Go
1998 Cherokee to Tow
1979 924 + 1977.5 924 + 1970 914 1.7 + MG Midget gone and not forgotten
Old 09-26-2008, 06:04 AM
Toofah King Bad
Nah, I think it was more likely a marketing decision. Porsche had a long run of producing 'entry-level' cars, and that slot was empty due to rising 944 costs.
Old 09-26-2008, 08:58 AM
Schumi's Avatar
I wish the fenders had stamp dates in them. It would be interesting to see when some of them were actually made. I'm sure at least the first year a group were made from old stock.
M
Old 09-26-2008, 09:59 AM
ERAU944's Avatar
Send a message via AIM to ERAU944
wow, that head gasket is atrocious!
i highly doubt it. in 1986 you could get a 924S ROW... this 'old components' nonsense is funny though
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 09-26-2008, 06:51 PM
Toofah King Bad
Indeed, the ROW 924 2.0 ended production in July 1985, and the 924S began the following month.
Old 09-26-2008, 09:08 PM
