944 NA vs. 951 tire sizes
944 NA 7" front wheel w/215 tires and 7" rear wheel w/215 tires
951 7" front wheel w/205 tires and 8" rear wheel w/225 tires On a front engine car with nearly 50/50 balance, why did they go smaller on the fronts? I understand with more power the rears would be larger, but making the fronts smaller don't seem right? Were the 215 fronts overkill just to make all 4 the same size on the NA's? What am I missing? ![]()
'99 996 Arctic silver over black. In the past I've owned and wrenched on a '96 Audi A4, '86 944 NA. '79 928, '72 914. Non-Teutonic vehicles of interest: 3 MGB's (one converted to V8 power), Triumph Stag & TR250, Jensen-Healey, T-Bird SC. Most recent "project" was a Factory Five MKII Roadster. |
Custom User Title
they wanted to make the car understeer so it was "safer". For your best handling go with equal sized tires all around.
Ok, Im interested in this one also. I dont want to hijack the thread. But since my car is a mix of power\944\951, I will
![]() I purchased a 944, turbo suspension \brake upgrades and a 320HP LS1 engine. The seller says 30lb heavier in the front over stock after mods. The tires on it now are 255/40R17 on all corners. Since I need spares, etc Im wondernig what might work for me. I have zero experience with a 944
theamsoilguy@hotmail.com |
White and Nerdy
A bigger tire does not mean more grip. Also, this thread is missing that 951's come with 16" wheels, instead of 15". If you put a wider tire on, it would defeat the purpose of going lower profile to start with. A wider tire on a wheel will bulge out at the sidewalls, which under heavy cornering strain will cause the tire to deform, losing grip. I run 205's on the front of my 944, and find it to be quite responsive in a corner. I had 255's on the rear, and moved to 245's, and now have a little more understeer in a corner unless I really try to break it lose.
Shadilay. Last edited by Tervuren; 09-25-2008 at 11:09 AM.. |
Custom User Title
A bigger tire means a larger "foot print" and more grip. If you put a 255 tire on a 6 inch rim you will run into issues as the tire is "pinched" and will deform as you say but you can easily run a 225 tire on a 7 inch rim according to Porsche and many tire mfgs.
On 7x15 inch rims I have run 215's all around and 225's all around. On 16 inch rims (7&8s) I have 225/245. 225/245 were part of the 944S M030 package on 7 and 8 inch rims and while the 245s look great the conering isnt the best as the front will push a bit. The equal sized tires will still understeer a bit but is much better balanced. I run 225's for track tires and the balance is much better than the staggered set up. Apparently 245's all around is the "hot setup"in the SCCA. 205/245 is a combo Porsche never put on a 944 series car as far as I know but I would bet that your driving style has adjusted to this type of set up. I think you would have to try different sized tires back to back to really see the difference. |
Custom User Title
here is a good start
http://www.cantonia.com/wheel_offset.html I dont know about moving to a much larger tire on a 17 or 18 inch rim but you can use this tire calculator to at least see the difference in sizes. http://www.miata.net/garage/tirecalc.html Aftermath - I would suspect a 255 tire up front would give you quite a bit of tramlining? |
it's not just the 205/55 and 225/50 on 7s and 8s that's puzzling; the factory tire pressure recommendation of 29 front and 36 rear with this tire/wheel size set-up is biased toward massive understeer
why? makes no sense to me
Warren '87 944S "Tubes sound better" |
