-   -   Hood Badge Replacement Procedure (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/432927-hood-badge-replacement-procedure.html)
kosh 09-29-2008 01:25 AM
Hey eveyone
Got a new badge coz the old one was in a bad state. anyway yesterday i thought i would put it on, so i released the screws on the front just where the shut line is on the hood and i thought it would just lift off and i could replace it.
Of course this was not the case. I pulled the metal up a bit and could see that the badge is held on with rivits!!! dam...
So has anyone gone throught this and where are the other screws or bolts that i need to remove in order to get the metal off so i can then get the badge off...of course if there is a quick method then id be even more happy.
ANy help would be very much apprecaited
Kosh
1986 924s 2.5l
hpservertech 09-29-2008 02:22 AM
Did you read the process on www.clarks-garage.com?
