scorp's Avatar
924 front seats into 944
Is this a pretty straight forward plug-and-play installation?
do the 924S driver/passenger (front) seats fit right onto 944 rails?
thanks
1989 944 2.7L n/a
Old 10-03-2008, 11:27 AM
scorp's Avatar
bump
1989 944 2.7L n/a
Old 10-04-2008, 01:55 PM
ERAU944's Avatar
Send a message via AIM to ERAU944
my guess would be no. 924S would be early 944 seats, and are not interchangeable with late 944 rails. if that's what you're asking...
Mike - CFI, A&P Mechanic w/ I.A., Aztec driver at Island Tyme
'88 951S - zermatt silber/black - staying stock. purchased in 11-2006
'84 944 - gemini grau/tan+brown - lightly modified. purchased in 11-2001
2021 Tesla Y - to get me to work
Old 10-04-2008, 08:35 PM
scorp's Avatar
thats exactly what im asking. the 924S is an 1986 though, that is why I was iffy
1989 944 2.7L n/a
Old 10-05-2008, 05:12 AM
earlr85944's Avatar
if you use the 924 rails it will bolt right in
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 10-05-2008, 06:29 AM
ERAU944's Avatar
i wouldn't be so sure about this. i tried bolting early 944 seats to late 944 rails, didn't work. i imagine vice versa would be out of the question...
the only way it would work is if the 924S uses late style seats and rails (which would have the provision for power). i'm not saying it's impossible, you'd just have to have someone with a 924S verify by comparing to a late 944.
Old 10-05-2008, 06:51 AM
earlr85944's Avatar
"i tried bolting early 944 seats to late 944 rails, didn't work"
thats a different scenario, im talking about using the early seats w/ the early rails into the late car, the theory is that the body is the same so the mounting holes are in the same spot
83 944....bye bye
Old 10-05-2008, 10:02 AM
ERAU944's Avatar
i tried switching seats for seats first - that was the easier and simpler way to go about it. unfortunately, the late seat rails had the seatbelts mounted to them, so i couldn't use the early seats in the late car. if the 924S seats are the late style, they will work for the 944. if they are early style they will not work unless you are putting them into an early 944.
Old 10-05-2008, 07:53 PM
scorp's Avatar
my 944 seatbelts are not part of the seat, and neither are the 924s seatbelts, which leads me to believe that they are interchangeable?
1989 944 2.7L n/a
Old 10-06-2008, 05:04 AM
ERAU944's Avatar
well make sure, they aren't on the seats themselves, but mounted to the seat rails. the frames of the early and late seats are different, so you can't mount one style seat to the other style seat rails. if the setup in your car is different and the seat belt is independent of the seat then i don't see why the switch wouldn't work.
Old 10-06-2008, 05:51 AM
