1984 944 Wiring Issue
Hi. I'm new to the forum so sorry if I somehow manage to screw things up.
I have a 1984 944 and I'm having an issue with my interior wiring. The previous owner put in an aftermarket stereo. However it didn't properly work. So When I went to replace it there was suddenly no power going through the wires. i checked the fuse and it's still good. However the clock, cig lighter and interior light don't work. and apparently they are all tied into the same circuit. Any ideas on what my problem may be? I have a Haynes manual but their wiring diagrams are useless. Any help is greatly appreciated. Thanks a lot guys. Cody. |
1984 porsche 944 na
you have power on fuse 7? put a test light on it and tell me if you still have power.
1984 porsche 944 na
Interior lights are grey/blue in harness run in series and brown for ground.
He may have tied the main power source to the cig lighter. You may have a couple of fuses for the stereo. Yellow wire is 12 volt source all the time for the stereo memory and red wire is ignition 12 volt if my memory serves me right.
