Send a message via Yahoo to jtango
power steering pump mount replacement
I am finally getting around to putting in a new(to me) power steering pump mount and before I dug in I wanted to see if anyone knows if I will need to take the water pump off in the process.
This is the piece that the lower balance shaft seal (and bearing?) are in at the front of the engine.
If I do then I'll need to order a new seal.
Thanks!
86 944na red (woohoo)
83' 944 gold (RIP)
94 Chevrolet Z71
Old 09-28-2008, 03:29 PM
earlr85944's Avatar
the pump can stay on
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 09-28-2008, 05:06 PM
Greasy Member
many944s's Avatar
As earlr85944 stated the pump can stay on.
Depending on the condition of the bearing and flange that rides on the front of the balance shaft, here are the various seals you will need:
944-105-321-00 - cam shaft mylar washer
999-701-652-40 - Balance shaft housing o-ring
999-113-281-40 - lower balance shaft seal
Usually the bearing is fine, but the flange often gets a groove in it from the front seal. If there is a groove on it you will also want:
928-105-139-02 - balance shaft flange
Hope it helps!!
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 09-29-2008, 06:45 AM
Thanks a lot guys. Just finished the job and put new front engine seals, new lower balance shaft bearing and power steering mount piece.
Probably the best part was fixing the lower balance shaft sprocket which was installed on the wrong keyway. I had suspected it for a while and I was happy when I was right, but now that I've driven it I can't wipe the smile off my face.
Also put on new sway bar bushings and the drop bar stiffeners.
Thanks again.
83' 944 gold (RIP)
94 Chevrolet Z71
Old 10-15-2008, 08:21 PM
