1984 porsche 944 na
ballysdad's Avatar
Early headlight switch help..
If someone can please reach back and pull their switch out and check something for me..
X= 12v when key is on...That I know..if you switch headlight switch on do you get power to 58L and 58R? you should but the 2 switches I have don't. The contacts inside both are worn and do not seem to make contact.
If I jump power to both wires without switch the tail lights work fine.
I even just put 12v to switch with all wires diconnected to see if I get 12v on the pins and I don't, in case a wire was shorted..Please verify for me.
Thank you
Old 10-20-2008, 02:01 PM
thekidd's Avatar
Send a message via AIM to thekidd
anything else just give me a ring, now that we have sunlight it may be easier?
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 10-21-2008, 07:07 AM
1984 porsche 944 na
ballysdad's Avatar
Thanks that was a big help..Let me know if that guy has a new switch. I can backfeed power through the switch and everything works fine but I don't want to leave it rigged..
Old 10-21-2008, 07:31 AM
