85.5 hesitates
My car runs relatively well, but i must say 2 things concern me. For one it seems under powered. I know some will say to get a turbo, and I can not agree more, but I feel like its really under powered. I accelerates and hesitates while doing so. My gas mileage really stinks too. My question is does the computer store codes. How do i go about testing. I think maybe I am running rich, but how can I tell. The AFM has been opened at some point by PO, so who knows. How do you guys determine if its running rich or lean.
That Guy
The computer does not store codes. Hesitation can be the wiper strip inside the AFM is worn out. You can check this by measuring the voltage through the AFM through the complete travel of the inner door. Check ClarksGarage for a how-to..
http://www.clarks-garage.com/shop-manual/elect-22.htm There is no easy way to tell if the car is running rich. The correct ways to do it are using an 3 or 5 gas emission analyzer which any place that does state inspections should have or to install a wideband O2 sensor. The other method is to check the voltage from the O2 sensor on the car, but this can be difficult because its hard to get a clear # and the accuracy of your #'s is dependent on the condition of the O2 sensor. The not so accurate ways to check are black smoke from the exhaust on acceleration and at idle the exhaust will make your eyes want to water. There are a few potential reasons for a car to run rich. Bad O2 sensor, bad DME temp sensor, mis adjusted CO adjustment screw on the AFM and faulty fuel pressure regulator are the most likely causes. A lean running car is usually a vacuum leak somewhere.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 Last edited by Techno Duck; 11-13-2008 at 08:50 AM.. |
Quality
Use the SAME filling PUMP, and get your mpg... Bad mpg of 25 is way different than 15mpg... =)
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
Hey phoenix, looks like your in my neck of the woods. I have a stupid question, and a bit embarrased to ask, but what does DE stard for. Is that driving experience. The people on these forums abbreviate alot, and sometimes I am scratching my head
That Guy
Drivers Ed, also known as HPDE.. High Performance Drivers Ed. Basically driving on a race track with a instructor.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Afm
AFM is preset adjustment from the factory to get a correct Air/Fuel mixture the same as in Carb. (the Old Days).
I have been fooling around with the AFM for sometimes and my conclusion is the AFM can be adjusted. This was the set up I have on my 85.5 944, the car was running perfect before the accident and I haven't change anything on the AFM ![]() ![]() On picture #2 the brown arrow is the adjustment to control the opening off the door the more tension on the door the less air it pass. And the blue arrow is the sweep to control the injector timing (how long it open) Rich/Lean. The adjusment screw outside the black cover is just adjusting the amount off off unmeter air, by passing the meter. Hope this info help ------------------------------------ Bud |
That Guy
Personally i would not adjust the AFM without first testing the other things i mentioned in an earlier post (DME temp sensor, O2 sensor, FPR). These are usually the big 3 when trying to figure out why its running rich. I would adjust the AFM as a last resort.
