High idle?
I've owned the car for nearly a year and have had no major problems than regular maintenance but i've always wondered if it idled too high. when warm it holds around 1200-1400 and is anywhere between 1000-1200 when cold. is this normal?
if not, what could be causing it?
thanks,
Kevin
1984 944 NA
A wise man once said, "Speed cannot be complimented with control, and that control is achievable only without speed." That man obviously has never driven a Porsche
Old 10-19-2008, 08:07 PM
nope, car is supposed to idle at 950 for the u.s. spec car, you idle control valve is sticking, either clean out or replace
1987 944 n/a
Old 10-19-2008, 09:45 PM
rsrmike's Avatar
84 doesn't have an idle control valve, just a little soleniod tied to the A/c compressor.
Perhaps the O-ring is old and shrunk on the idle adjustment screw, or it just needs a turn clockwise to lower the idle, if it turns really easy, try to find a new oring, or pull it out and put a small amount of loctite on it ( just remember to set the idle before the loctite cures!!)
Professional Overcomplicator
Old 10-19-2008, 09:56 PM
rsrmike's Avatar
Perhaps the engine mounts are/were tired and someone raised the idle to reduce some of the chatter
Old 10-19-2008, 09:57 PM
I'll keep you from feeling lonely. My 84 does the same thing.
It's on my to fix list, but so far I haven't found any easy fix for it. I've only had this heap running for about 3 months now and there's still a pile of bigger issue that need addressing first.
Life's short
Go fast
Have a blast
Leave a good looking corpse in a 84 944
Old 10-19-2008, 10:24 PM
if it isn't actually broke, i don't wanna have fix something. it hasn't hurt anything that i can tell so if it isn't going to, i'm not going to mess with it.
does that sound like a bad plan?
should i actually look into it?
1984 944 NA
Old 10-20-2008, 08:44 PM
flash968's Avatar
after checking to see if you have a hose lose, grab a can of carb cleaner and squirt it around the intake looking for a vacuum leak
Old 10-20-2008, 09:04 PM
ok will do, thank you guys for all your help
1984 944 NA
Old 10-20-2008, 09:40 PM
