shifting gears little problem
so after a new clutch job shifting gears is not as smoth anymore..when i switch the gears seems like i hit something metal before i make the shift..seems like i have to wait for the rpms to come down then i can make a more smother shift...dose the clutch need bleeding? how can i adjust this? thanks for any help..it was really smoth before the clutch job and had the rubber clutch and it was bad..
i have the same prob but its only from 1st to 2nd but it goes away once the car is warm
mine dose not go away
LSD tranny?
the reason i asked if it had LSD was I had a LSD tranny in my 85.5 and couldn't screach the tires even if I tried, good. But I would rev up to about 5k and couldnt get it into 2nd gear right away, let the rpm's drop a few and it would shift to 2nd easy, same thing in 3rd, but shifted easier. I thought that you had to bleed the clutch after putting in a new clutch. Its an easy job, just put in a new slave and master cylinder on mine. You have to remove the starter to get to the slave so you can bleed the cluth system- to get a better bleed- early- jack the front end up, late- jack the back end up to get most of the fluid out. Clarks write-up C:\Documents and Settings\Steve\Desktop\Clark's Garage Home Page.mht
| All times are GMT -8. The time now is 06:15 PM. |
