Porsche Crest 944 crank sensor
hey people,
so i just bought a 1985 944, the car doesnt run, the lady i bought it from says it ran fine and one day she came back to turn it on and it just wouldnt start... the engine still turns over but theres no spark... is it the crank sensor? how much would one cost plus labor? or is it just a piece i can put in myself? with an ohmz meter how would i test it?
Old 10-28-2008, 05:15 PM
75ohm's Avatar
www.clarks-garage.com for testing procedures and yes, you can do it yourself!
www.rennwish.org
'88 944 NA - Red/Black with more tinkering done than probably needed.
Old 10-28-2008, 06:14 PM
Custom User Title
mikepellegrini's Avatar
Pelican has the reference sensor for $163 - which is kinda high. http://www.pelicanparts.com/catalog/shopcart/944M/POR_944M_FULinj_pg2.htm#item5
The best deal I've seen is at Lindsey Racing - $72.95 for a generic Bosch sensor! (which is exactly the same as the OEM Porsche part) - http://www.lindseyracing.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LR&Product_Code=944-606-115-00&Category_Code=944ELECTRICAL
The speed and reference sensors are both the same.
Used, I've bought them for as little as $25 (from parts cars).
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 10-28-2008, 07:56 PM
Send a message via AIM to Lapponia
Caleb! It could be a simple matter as a Bad DME-relay e.g. a burnt contact in it. If the relay contacts doesenīt let current go through them you will NOT have the DME computer energized and the ignition will NOT work. So, try to change the DME-relay first, itīs on the second place from left on the upper relay row if 1985 is like my 1984. The relay is cheaper than sensors and you will need one anyway as a spare. Good luck!
And Caleb, welcome to this GREAT board!
__________________________________________
Lapponia 1984 944 na
Old 10-29-2008, 04:12 AM
thanks!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-29-2008, 11:49 PM
