944paige
HI GUYS again I'm tinkering and want to remove the power steering in my car for a manual my question is if i remove the pump, hoses, and reservoir and drive it just to get back and forth to the mechanic or body shop what other components will i damage i don't care about the rack since i plan on changing it also i would like to remove the cruise control unit to clean up the engine bay what will i need to do ....thanks
If you cap off the rack where you remove the lines from, you won't hurt a thing. In fact, some people leave it like this and have pseudo-manual steering. If you don't cap off the rack, it will pump fluid all over the underside of your car every time you turn the wheel. It won't hurt anything (short term), but it will make a mess.
When I removed the cruise from my car, I just unplugged it from the wiring harness, cut the cable where it goes through the firewall, unbolted and yanked it out.
Dan Former owner of: '88 924LE (Luddite Edition) manual steering, manual sunroof, manual windows, AC delete, cruise delete, M030 Konis, 25.5 torsions, 931 valance and header panels, 6X16 Fuchs, lowered, etc, etc. |
944paige
THANK YOU VERY MUCH ......o.k just have to figure out how to cap the rack....
Back from Beyond
Find bolts the right size to fit where the banjo bolts come off (or reuse the banjo bolts and seat them all the way in - I can't remember) and that'll plug the send/return lines for you. The use a length of vac hose to run between the two outlets on the rack itself. I've run a power rack with no power for years. Some think it's heavy parking the car but I don't mind it.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
