Please diagnose my clutch
'86 RoW 944 with 116,000kms. original clutch.
the clutch has always had a bit of travel making smooth driving difficult without thinking about it. It doesn't seem to slip at all. lately the shift has been feeling notchy. last weekend i was on a 3 hr drive down country and the notchiness was getting worse until I suddenly couldn't select a gear at all without seriously manhandling the gearshhift more than I should have to. I made it to my destination 40 mins later and the problem had mysteriously stopped. On the return trip the clutch was now noisey- it makes a mechanical thunk sound when the gear is engaged and the clutch let out. I can hear this at speed with the window down too. when driving, with no throttle input and then giving it some gas, the whole car does a big shudder as the power comes on, same for when i take my foot off the throttle. it does this from any throttle level to 0 throttle unless i let it off very gradually. it goes into and out of gear fine, just that mechanical thunk sound. TIA
https://www.instagram.com/kiwi944s3/ '86 944S3 conversion - '94 968 3.0 engine - 6 spd/LSD - 17x8,17x9 Oz Racing Crono wheels |
Learned by do'n twice
Sounds like the rubber center is shot and you are running on the "limp home tabs". Inspect the clutch via the inspection port hole in the bellhousing to see if you find rubber grit or chunks. Use a flashlight for better view. If the rubber center is shot, you will need to replace the clutch.
jmd_forest
86 944 NA - Brought back from the dead |
i was wondering if it would be that, I have heard of the infamous rubber centre clutches.
got my car on stands now and can't make anything out with a torch. had a feel around but its just old oily grimy mess, i'll try again now though with some tools to try and pick something up (if anythings in there). I'm guessing from the lack of input theres not much else it can be?
Sound like a clutch ob to me.Don't forget it a 22 years old car the infamous rubber centre will dry up and became brittle.
I have replaced mine at around 160k mile 8 years ago, but the shop replaced it with the after market clutch which has a spring loaded dampening. But I don't like the way the car drive, shake on upshift and downshift as the clutch make contact. I replace the clutch mydelf with the Oem clutch(With the infamous rubber center clutch). Good Luck ---------------------------------- Bud 87 930 Black 86 951 Black 86 944 N/A part car 87 944S White 83 944 N/A Black 83 944 N/A White Auto |
thanks guys
![]() have been looking at the clutches available on pelican. which is the better option? oem spring centre or the centreforce clutch?
Back from Beyond
OEM spring-centered is fine.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Nobody Special
Another good way to check if it's the clutch (it sounds like it) is safely jack up the rear end, trans out of gear, reach into the transaxle inspection hole and try to twist the driveline. If it rotates more than 1/16" your clutch is toast. The limphome tabs on my 83 looked hammeded but the car was still shifting fine, it just clunked real bad on and off throttle. The Sachs spring centered clutch is the way to go for a NA although there is a Mazda disc that works for much less.
86 - 951 - Garrett dbb T3/T4R/Tial/Maxtronic -SOLD 91 - BMW 325 iX AWD, 5-spd Coupe, Lazur Blau Metallic-SOLD 86 - 951-K26/8, daily driver-SOLD 87 - 944S - Another daily driver-SOLD |
Redline Racer
and what Mazda disk is that?? I'm always up for cheap fixes that work.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky |
Back from Beyond
Mazda disc? I'm all ears too!
Nobody Special
http://forums.rennlist.com/rennforums/showthread.php?t=451563&highlight=disc
Thanks again
the centreforce is some 100.00 cheaper which is why I ask...?
Proprietoristicly Refined
The Vertex clutch disc mentioned by 2Tight looks new and not relined--Price $199 each. One poster mentioned vibration but I think the disc would not cause this. The vibration is usually the flywheel and PP not balanced before assembly.
http://www.**********.com/ShowItem/677%20Porsche%20Power%20Friction%20Clutch%20Disc.a spx John_AZ |
![]() a friend pointed me towards zims also. http://www.***********/acatalog/Clutch_Disc__Spring_Hub__944_S_S2.html why right before xmas!?!
Is it OK to buy just the clutch plate and not the 3 piece kit? I assume doing this would require the pressure plate to be resurfaced.
M |
Redline Racer
yeah, how can you tell if the pressure plate can be reused or not?
Back from Beyond
Centerforce - I thought these were for high-horse applications and would be a bit heavy or jerky for daily driving. Sorry if I'm wrong!
I'd think that checking the pressure plate for runout/out of tolerance, looking for burned spots or cracking would be a good inspection. I'd read about the Bronco clutch being used on a 931S2, and the issue was the spline housing offset. The guy who used the Bronco disc, IIRC, drilled out the rivets and put in bolts/locking nuts. Apparently it's working fine. The same clutch setup is in the 944. Do a search on www.924board.org and see what comes up. HTH
Redline Racer
How about the spec clutches on lindsey? anyone ever tried those before?
