Bolt Stripped!
I am currently in the middle of taking off my power steering rack but I have run into a problem...
The hex head hollow bolt connecting the power steering return line to the steering gear housing is stripped. There are obvious teeth marks from someone using pliers/vice grip on it as well. I have tried with a vice grip to no avail, but its a really tight spot and the return line itself gets in my way of making any headway. Any advice? I was thinking of taking off the return line WITH the rack and then removing it afterward when i have more room. |
I probably have a good banjo fitting if you need it, it would be several days before you got it though... Proly not worth the hassle unless it gets boogered up too bad to reuse Good luck
Professional Overcomplicator |
stripping the head on a hollow bolt, and not just breaking it, now that takes talent. How much you want to bet it breaks when you try getting it off. Should be fun either way.
dude Last edited by mistertate; 11-02-2008 at 09:06 AM.. |
Automotive Necromancer
solution
OXY-ACETELYNE torch!
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. |
I have these Deals called bolt extractors. Never tried them but they look promising.
![]() Not the same brand but maybe you could try one of those? |
remove the rack
place it in vise with wood blocks (or B&D workmate) take a slightly larger size 12pt allen socket (cheesehead) hammer it into the stripped bolt heat with heatgun if there's no rubber within a few inches say a quick prayer and turn it i've also gotten them out with SAE allen sockets too |
disregard my post
i didn't read yours closely i thought you stripped the allen head where the line connects to the rack |
i've used them too with good luck |
