hermesbooking's Avatar
Send a message via Yahoo to hermesbooking
no fuel from fuel injectors
well again with the issues with my car. one of the guys said to remove the fuel rail from the block and turn over to see if the injectors were firing. well after testing twice grounded and ungrounded. well got nothing from the injectors at all. I have two dme relays one new and neither made any diff. any suggestions where to start. thanks mike
I Love the Smell of Jet Fuel in the Morning!
86 Silver Porsche 944 N/A - Alpine CDA-9857
KYB Front, Weltmeister 250lb springs, MSD Master Blaster Coil, K&N Cone Filter, Blue LED Dash, Clock and Defrost Upgrade
http://www.c28.com/?adid=st&iid=25349
Old 11-08-2008, 06:22 PM
Hi, while turning the ignition key over and cranking the engine have a friend with a voltmeter test to see if you are getting 12volts to the fuel pump and if you are indeed getting 12 volts your fuel pump may be bad.
Old 11-08-2008, 06:59 PM
TibetanT's Avatar
Mike, I PM'ed you some info. What I did not mention is, do you know for sure that your battery is good and you have at least 12.5 volts. Because, if you don't then the injectors will not fire.
Second, since I am coming late to the party, I apologize if this is redundant, but how is the timing, spark plugs, spark plug wires, rotor, cap, cam belt timing on the money, and compression from cylinders. All of these play a role in keeping the car going as well as alternator presenting voltage to properly recharge the battery...usually around 14.0-14.76 when running.
Third, does the car turn over and run if Starter Fluid is used within the housing to the intake manifold? If the car turns over, then start looking into whether or not the reference sensors are doing there job. Especially since you have a new DME/ECU brain, you know the computer is working so the problem could lie in the wiring harness system which delivers information to the DME relay in the fuse box.
Hope this helps!
Ed Paquette
1983 911SC
1987 944S
1987 944 Manual (Donated to the Nat. Kidney Foundation)
1987 944 Automatic (Recently sold to another Pelican)
Old 11-08-2008, 07:21 PM
