Ring and pinions for the 944
Are there any companies that sell different final drive gears for a plain old 944.
I am trying to drop the RPM some at highway speed on a project of mine.
This obviously would require a higher gear (lower numerically)
Does anyone know of any options.
Old 11-10-2008, 04:23 PM
Redline Racer
HondaDustR's Avatar
The turbo transmission has higher gearing I think. There's also bigger tires. I don't think there are any regular production replacement gearsets for the 944 box that change the ratios.
I gained ~200 rpm in 5th at around 65 mph when I went from a 195/60/15 to a 205/55/15 in the rear. It would most certainly work the other way for your aplication.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-10-2008, 05:36 PM
I am running a 275/40/17 now and I can't go much bigger.
If my math is correct then that would put me at 2958RPM at 70MPH
I would love it if I could get that down to around 2000-2300RPM.
The 951 gears would get me down to 2567 which I could probably live with.
Are the gears interchangeable with the standard 944 boxes?
Anyone have any busted 951 transmissions they would like to sell so I can yank the gears out?
Old 11-12-2008, 10:11 AM
Redline Racer
HondaDustR's Avatar
What about 6th gear in a 968 transmission? I don't know if it would bolt up to a 944 driveshaft , though.
Old 11-12-2008, 12:52 PM
If I had to guess I would say probably not.
I would probably be better off just buying a 6 speed.
I suppose I will just live with the revs for now.
Incase people don't know I am talking about my V8 Rabbit project.
I figured in such a light car (2200lbs) that I would not need low gears to get moving so I would swap them out for a little lower revs on the highway to save some bucks on gas as well as wear and tear.
I also would like to avoid having the turbos spooling up too much on the highway unless I want them to and I fear that if the engine is approaching 3000RPM then they may be starting to spool up.
I guess I won't know that until it is up and running so i will just worry about that then.
Old 11-12-2008, 04:29 PM
