Sunroof gone AWOL
Hi guys - evidently it is pretty common for the sunroof to act up. Other than pull the headliner down is there a way to get the fitting that attaches to the sunroof re-engaged with the roof? Mine has disconnect so the roof isn't secured at the back any longer and this isn't locked in place and can't be tilted.
Oh, and thanks for the coaching on the brake calipers. Stupid easy to fix once I actually stared at it a bit longer and nudged the caliper some.
Thanks!
Old 11-14-2008, 04:29 PM
Custom User Title
Dave L's Avatar
There are very good instruction on clarks garage to operate and if required repair the sunroof. Follow them to the letter and if you have stripped the gears (I bet you did) be sure to adjust the clutch or you will find yourself ordering a few sets of gears and lying in the back of your car a few more very frustrating times.
Old 11-14-2008, 06:09 PM
thekidd's Avatar
Send a message via AIM to thekidd
Different sunroofs for the late 944's than they 944/924 series. But the most common problem is the stiped plastic gears on the late models. Clarks trouble shooting page- C:\Documents and Settings\Steve\Desktop\Clark's Garage Home Page.mht Hope you get it working so it doesnt fly off hen your driving
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 11-14-2008, 06:47 PM
Just thinking out loud
mattdavis11's Avatar
Twist the latches 90 degrees, let the roof fall in place, twist them back 90 degrees and fold the latches up.
Oh, wait..... you have a power sunroof huh? That sux.
91 FJ80
84 Ram Charger (now gone)
Old 11-14-2008, 07:47 PM
Thanks guys - I'll dig through the Clark's site. Appreciate the info/help!
Old 11-16-2008, 03:51 PM
