-   -   turbo rear arm comversion (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/443517-turbo-rear-arm-comversion.html)
jhelgesen 11-27-2008 05:04 PM
I'm about to put turbo 86 rear arms on my early 85 car. Will I need to change out the spring plates also?
Thanks!
Ez-Bone 11-27-2008 05:56 PM
I too am curious as to what I would need to do to convert
JivenJim 11-27-2008 09:06 PM
Pretty sure you will have hub offset/wheel issues unless you switch to late wheel and late hubs 23mm vs 53mm. I don't think a new hub would fit on an older trailing arm. I think there is also difference on the upper spring arm but not sure what. Maybe you could do it with spacer plates and longer hub studs.
944 boy 11-27-2008 09:45 PM
Not quite, the 86' trailing arms (turbo & NA) are aluminum and early offset. 87+ was when the offset changed.
As far as i can tell you should be able to just bolt on the 86 trailing arm to your 85. the camber adjuster tool is the same for all years.
