-   -   Adjustable Spring Plates? (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/443613-adjustable-spring-plates.html)
flashgordon13 11-28-2008 02:56 PM
Does anyone have any info on adjustable spring plates like the 911 guys use for a 944? I plan on changing my T-bars and thought it would be a nice mod to have adjustable spring plates as well to make ride height adjustments painless. I have searched around but haven't found any info to build my own or a supplier that sells them. Any help would great.
flash968 11-28-2008 04:11 PM
not sure what is different about the 911 ones, but isn't the adjustment in the 944 plate enough? do you not have that already? am i missing something here?
flashgordon13 11-28-2008 04:55 PM
The aftermarket spring plates for the 911 that I have seen have an adjuster that looks like it has much more adjustability range than the 944 plates. The ease of adjustment looks like it would be worth the effort. I also thought it would make the torsion bar install a lot easier with more adjustment range so that bar indexing would not be such a nightmare. I am not sure if I am missing something or not so I figured I would find the answers here. Sorry if I wasn't clear in my original question. I guess I am just getting lazy as I get older and trying to find an easier way to do the torsion bars.
flash968 11-28-2008 06:11 PM
no worries - i think i may remember the ones you are talking about - are they the ones that have a bolt or something to adjust the arm, rather than the standard eccentric?
flashgordon13 11-28-2008 06:16 PM
Yes, those are the plates I have seen. They look like they would be an improvement over the stock plates, but I just don't know and can't find any info.
flash968 11-29-2008 06:07 AM
have you tried paragon? i know they carry the ones for the 911 - no idea if they fit though, and not sure if they carry anything for a 944 series
other than that, i would try tarret
