Wire connector coming from distributor?
I have a connector coming from my distributor that isnt plugged into anything... Its the same plug type that would go into the warm up regulator or the fuel distributor. Where does this plug into?
1977
924
Old 11-28-2008, 12:46 PM
It goes to what the book (Haynes) calls it the transistor ignition unit. As I remember it is located on the drivers side wheel well. It has been a while and I would have to do some reading to give you the logic and how it works. I believe it affects timing.
Jon
87 924S
82 924-Gone.
80 924 parts car-Gone.
Old 11-29-2008, 07:15 AM
If thats where it plugs in damn... the wire is only about 8inches long.
Old 11-29-2008, 10:04 AM
As I recall the female plug on mine was attached to the distributor. The male plug with leads was a 3 wire. I don't remember how it was routed.
Hope this helps.
Jon
87 924S
82 924-Gone.
Old 11-29-2008, 04:19 PM
