Gasket Help
ok preparing to put everything back together and need help ID gaskets from my HG set and front reseal kit. These don't have any part numbers so I'm scratching my head.
![]() the top one in the packet. -from the front reseal kit- Front Back And 5 little seals that are drawing a blank...On a side note, my reseal kit came with 2 upper, and 2 lower balance shaft seals. My HG set came with 2 cam seals. I don't think that is normal but I'm happy.
dolor et pavor Copyright |
That Guy
The first two seals are for the water inlet and outlet on the cylinder head. The left seal being the front goose neck, the rear seal being the inlet from the heater core. Not sure what seals specifically are in the middle picture without measuring, but my guess is the left one is the crank seal for the early 944 (83-84 i think) and the right seal is for all other engines.
The o-rings on the bottom, the thicker one on the left is for the cam housing, the two others if the same size look like they are for the balance shaft housing cover. The small o-ring is for the o-pump drive sleeve..and that clear bushing is for the camshaft also.
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
thanks!!
Back from Beyond
Second picture right seal looks like it's for the cam front.
Techno is right about the others.
'88 944 Auto - project, kinda '87 944 Auto - died saving my wife '84 944 5SP - crushed under shop roof during snow storm All others GONE! |
Back from Beyond
Sorry - dbl post.
