USMC_944lover's Avatar
Send a message via AIM to USMC_944lover Send a message via Skype™ to USMC_944lover
Question 944 n/a, Caliper Rebuild Kit
Hi everyone. I need some assistance again if possible.
I have a 1986 944 and have a leaking caliper where it meets the shoe. I can visually see that the rubber is damaged and I cannot hold any pressure while hitting the brake. I bought 2 new caliper rebuild kits and was unable to find a reliable source on replacing them. As to all porsche things, there is nothing that is just simple. Always has a twist. I was wondering if anyone could help or show me a site to fix this. Or is it simple? Thanks!
robert
Porsche 944 1986
"The art of war is simple enough. Find out where your enemy is. Get at him as soon as you can. Strike him as hard as you can, and keep moving."
-Ulysses S Grant
Old 12-03-2008, 08:39 PM
Aslet's Avatar
The kit did not come with instructions? Also, it is simple... Take it apart and rebuild in reverse order. Haynes manual also has instructions. So I would recommend using the Haynes manual at least, with the book it is easy to do. The only tricky part is that the piston has to go back in the same way, since it has a raised section on the part that touches the pad (applies equal pressure to the pad, so if not replaced in the same orientation you may get vibration when braking). Again, what kit did you get, and did it have no instructions? I bought the ATE rebuild kit from Pelican and it came with detailed instructions (no pictures, so the Haynes was nice to have too). Let me know if this helps at all of if you need more info.
-Randy
1984 944 -Race car project
1993 968 coupe- Amazon Green
Old 12-03-2008, 08:46 PM
Back from Beyond
Quite a relaxing little project, these. The potential pitfall is the piston getting stuck in the bore when you try to remove it. Some use compressed air to get it out if it sticks. I just worked it round as I pulled.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 12-04-2008, 01:58 PM
Proprietoristicly Refined
John_AZ's Avatar
Robert,
Here is an excellent link to help you.
Rebuilt the Front Brakes - Nasty Grime Inside! (pics)
Make sure you click on exitwounds post #6 file on bottom.
GL
John_AZ
1988 924S + 1987 924S
Old 12-05-2008, 05:55 AM
I bought an ATE rebuild on ebay. It came with instructions but like you said no pics and somewhat confusing. I do have a haynes. I didnt even look at that cause I figured it wouldnt have rebuild kit part, just take off and install.
thanks everyone. im gonna get ready to do this.
Good to see you again John. thanks for the info also.
Porsche 944 1986
-Ulysses S Grant
Old 12-06-2008, 11:45 AM
Porsche 944 1986
-Ulysses S Grant
Old 12-06-2008, 11:46 AM
