Turbo_ZA's Avatar
Send a message via ICQ to Turbo_ZA
A/F Ratio Gauge on Eurospec 952
Is it possible to hook up an Air/Fuel Ratio Gauge on a Eurospec 952, which does not use an o2 sensor? If so could someone point me in the direction of the instructions or info?
1988 952 - Gold (Almond Beige Metallic), 18" Work Equips
2000 Jeep Cherokee XJ (Yes a SUV! - some days I feel the need to be a roadhog)
Old 12-08-2008, 10:03 AM
Schumi's Avatar
Many people choose to go the wideband route. I would recommend the following site.
http://www.innovatemotorsports.com/products/MTS.php
M
Old 12-08-2008, 10:08 AM
Turbo_ZA's Avatar
So I would need to have the bung welded to the downpipe below the manifold flange - basically retrofit the exhaust to take an o2 sensor, in effect?
Old 12-08-2008, 10:39 AM
Schumi's Avatar
If there isn't already a capped off bung (which is a possibility), then yes.
M
Old 12-08-2008, 11:17 AM
Turbo_ZA's Avatar
Thanks for the info, I will put this off until the porker goes in for it's custom 3" free flow SS exhaust. No point doing it twice.
Old 12-08-2008, 12:04 PM
