North Coast Cab's Avatar
Where to Mount Auxiliary Oil Cooler
I am installing an auxiliary oil cooler on the 944 and I am looking for some installation advise. I am using tan oil filter sandwich plate to tap the oil and need to install a 16row oil cooler. Is in fron tof the radiator the obvious spot or is there another solution?
TIA, John
1985.5 944 GTS
Old 12-13-2008, 05:44 AM
That Guy
Techno Duck's Avatar
With the n/a front valance your spaces are limited. I would go either right infront of the radiator (remove the a/c condenser of course) or i would remove one of the fog lights and put it behind there.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 12-13-2008, 07:39 AM
fast924S's Avatar
Send a message via AIM to fast924S
I did one on my 924s but it's setup different then the 944 mine runs all the way to the drivers side, I had to modify the front valance for air flow, the last place I would put it is infront of the rad, then your just dumping the heat into the coolant which defeats the purpose of a external oil cooler
Old 12-14-2008, 07:35 AM
I put it in front of the radiator. Yo ucan get these ty-wrap fasteners that are designed to stack cooler and radiators and it takes 2 minutes to secure them.
1985.5 944 GTS
Old 12-14-2008, 07:46 AM
That Guy
I understand why it would seem stupid to put the oil cooler infront of the radiator, but alot of guys run a 2nd gen RX7 oil cooler in that spot because its such a good fit. I think the most important thing is to have the a/c condenser removed so you get the best flow across the radiator.
Jon
Old 12-14-2008, 09:54 AM
