Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
One apex at a time
Dean924s's Avatar
Zip Ties - AKA don't try this at home.
OK The reason I did this was because I was at home and my spring compressor was not. (I could not find my spring compressor.)
Since my springs are not stock and lower the car about 1-1/2 inches the total amount of compression I needed was very small.
It did work for me but I was very careful to never have the spring pointed at me through the whole process. In fact I am not going to tell you how I did it. If you are smart enough to make it work you are smart enough to figure out how I got the springs compressed. There is a very specific order to how you do this is the only clue I will give.
If you try this and get hurt don't blame me.
Respectfully
Dean
General Car Specs & Mods
Project Megasquirt 924s
Old 12-15-2008, 07:17 PM
Schumi's Avatar
The issue really isn't weather or not it is pointer at you if it broke- the issue is having your fingers around it if it broke. If you had your hands around the top flange and those decided to let go, it easily has enough force to nearly sever your fingers.
That being said this is something I would do.
Be safe...
Mike
Old 12-15-2008, 07:22 PM
AZ_porschekid's Avatar
how are you gonna get these back to normal?
85 928S; LSx conversion, 5 speed with LSD.
Old 12-15-2008, 07:29 PM
fast924S's Avatar
Send a message via AIM to fast924S
Ohhhh man bro, scary lol, sooo what are you pulling the suspension for???
Old 12-15-2008, 07:35 PM
One apex at a time
Dean924s's Avatar
Originally Posted by fast924S View Post
Ohhhh man bro, scary lol, so what are you pulling the suspension for???
New Koni sports. The set I put in back in 1993 finally died. Turns out I should have installed the bump stops that were supposed to come with the struts but did not.
They are now special order and will set you back another $25 but they will prevent you from bottoming out the strut (what killed mine).
Respectfully
Dean
Old 12-15-2008, 07:39 PM
One apex at a time
Dean924s's Avatar
I am not sure of the question. The springs are IBOC progressives the bottom of the spring is very soft. If you look at the photos you will see that the coils at the bottom are very close together. This is the normal spacing of the spring at this location of the spring. The upper half of the spring has very broadly spaced coils and is very stiff (why it is a progressive spring) I only compressed the bottom and the total compression was about 2 inches to spring travel total.
Respectfully
Dean
Old 12-15-2008, 07:42 PM
One apex at a time
Dean924s's Avatar
Be safe...
Yep. I only wore gloves and only handled them by the sides with two hands pressing the spring between my palms. On the sides of the coils not on the ends of course
I have seen these things let go and it is quite impressive!
Respectfully
Dean
Old 12-15-2008, 07:45 PM
why not use few of those metal thing you put around intake,they are strong as hell...
Old 12-15-2008, 08:19 PM
yea i wouldn't have done that with zipties. why do u do this when you can rent at spring compressor at autozone for free?
Old 12-15-2008, 08:22 PM
Will work for parts
944 boy's Avatar
Send a message via AIM to 944 boy
I did the same thing in a pinch with a pair of motorcycle tie-downs. Worked well actually, but it was just to disassemble a strut and not to re-compress it.
'88 944 240,100 miles -race car
'05 Boxster 110,000 - Daily Driver
'74 911 Targa - long term project
Old 12-15-2008, 08:54 PM
One apex at a time
Dean924s's Avatar
Originally Posted by krystar View Post
yea i wouldn't have done that with zip ties. why do u do this when you can rent at spring compressor at autozone for free?
Sunday night. Needed car on monday morning. I thought I had mine when I started the project.
I like the idea of using straps. I Must remember that one.
Respectfully
Dean
Old 12-16-2008, 05:31 AM
your average wrencher...
i love zip-ties!!!
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 12-16-2008, 11:43 AM
ah i see. i think a the inner area of a big C clamp would be safer though
Old 12-16-2008, 11:49 AM
One apex at a time
Dean924s's Avatar
Zip ties are the third piece of the space time continuum. Next to Duct Tape, Crazy glue of course.
Respectfully
Dean
Old 12-16-2008, 12:09 PM
Redline Racer
HondaDustR's Avatar
Desperate times call for desperate measures...and zip ties FTW!
1987 silver 924S 210k mi! - Rebuilt motor survived 60K so far. Bottom end balanced, Custom mild ported head, Port matched intake, LR 944MAX chip, Thush Welded muffler, Bilstein shocks, MSD Blaster 2 coil, ect ect...Needs 8 more valves!
2003 Hyundai Tiburon GT 2.7 V6 24V DOHC- New toy/backup plan...Borla cat back, Injen intake. Needs headers and a real set of cams.
Old 12-16-2008, 12:22 PM
lol hondadustr.
i'm all for usage of zip ties. just not when my life is on the line. my front bumper is held on with zipties, as is my electrical system switch panel (gutted interior)
Old 12-16-2008, 12:45 PM
One apex at a time
Dean924s's Avatar
After I got it reassembled and the weight was back on the strut.
A pair of dikes (not the female kind) was all it took.
Respectfully
Dean
Old 12-16-2008, 04:26 PM
flash968's Avatar
hate to bring this up so late, but if you had merely unbolted the sway bar from the control arm, you could have swung the control arm down and avoided the use of the compressor all together
Old 12-16-2008, 07:12 PM
One apex at a time
Dean924s's Avatar
Nope. Not true. You need to compress the spring to get it back on the strut. Compressing the spring had nothing to do with getting it out. Getting them out from under the car all you have to do is jack up the whole front end so both sides are hanging. Then unbolt both sides and they just drop down together. Everything rotates down including the sway bar. It makes changing struts in my car a really simple job. Since my car uses the inserts I don't even have to take the bottom apart at all meaning I don't need an alignment when replacing struts. I did both sides in under an hour. You spend more time jacking up the car and placing the jack stands then you do actually replacing the struts.
Respectfully
Dean
Old 12-16-2008, 08:23 PM
Zero10's Avatar
Send a message via ICQ to Zero10
I hate to admit it, but back when I first started working on cars my dad helped me to umm "secure" some springs on a strut using a coat hanger twisted around the spring. Like you I will spare the directions for doing this in favor of not harming the less mechanically inclined, but this thread reminds me of the good old days
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-16-2008, 10:23 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
