low944's Avatar
Send a message via AIM to low944
944 S2/968 diagnostics software in va??
Does anybody have a diagnotics tool/ software that will work on a 944 S2 to reset the airbag light in northern VA?? Would you mind lending/renting it out for a quick reset of my airbag light??
Thanks,
James
JW
1983 911 SC
1990 944 S2 (sold)
Old 12-16-2008, 12:59 PM
In the Fires of Hell.....
kdjones2000's Avatar
I think that the later models can only be done at the dealer.... unless someone has the magic tool you are looking for.
Good luck!
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 12-16-2008, 08:35 PM
Will program for food
ghnat's Avatar
I just reset mine using the info from Clark's garage. Look for the white molex connector (should have a red rubber cover over it) in the right foot well.
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 12-17-2008, 04:17 AM
The magic tool is the Bosch Hammer, an early diagnostic tool. Typically, the 1991 and newer cars are the ones that need it.
As Greg states, Clarks Garage has a nice writeup on resetting the airbag light on the 1987 to 1990 cars. Requires a jumper wire and a watch with a second hand.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 12-17-2008, 04:43 AM
low944's Avatar
Did your light stay out after reset?? I wonder why this happens? I am going to give the clarks garage thing a try today. Ill post my outcome. I actually was planning to do that already and could not find that little molex connector until this morning after diggin way up under the dash.
JW
1983 911 SC
1990 944 S2 (sold)
Old 12-17-2008, 06:30 AM
ghnat's Avatar
JW,
Initially no. I learned how to read the fault codes (Clark's Garage) luckily diagnosed the issue and bought a part from George at 944 Ecology (quick shipment and nice to deal with). The light is off but I have not had any time driving, working on cruise control issues. As a matter of fact a fellow PCA member has donated his Cruise Control brain (I think mine is bad but not sure). I'll know more this weekend as I hope to have most issues resolved by then.
Greg Hnat
98 Jeep Cherokee
Old 12-17-2008, 02:43 PM
