how much it cost to repair a chipped camshaft
and who can do it? is it worth it?might as well get a used one?
Old 12-17-2008, 09:20 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
Life is a grind...
A "cam grinder" or good machinist could build up the lobe with a bead of weld and then mill it down, assuming that the chip is not too big. You would have to magnaflux the cam to check for cracks. Check around local machinists / welders.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-17-2008, 09:46 PM
TNT25169's Avatar
Send a message via AIM to TNT25169
I sell used cams in good shape for under $100. Just an option, I can't imagine a welder doing it for less than a couple hundred.
-1988 Black 944 w/ yellow koni's, coilovers with 250lb springs, adjustable camber plates, strut tower brace, weltmeister front and rear sway bars, 968 caster blocks and 5 pt harnesses
www.apartabove.com
Old 12-17-2008, 09:47 PM
sent you a message
Old 12-17-2008, 10:25 PM
i cant imagine how hard it would be
Old 12-17-2008, 10:32 PM
if anyone has a intake cam for 944S let me know i need one..
Old 12-17-2008, 10:47 PM
Greasy Member
many944s's Avatar
Find a replacement cam!!
Camshafts are works of art in that the surface of the lobes is hardened.
Almost every weld is going to have gas pockes created by the heating of the metal, when the surface is "re-ground" these pockets will be exposed. The other thing to keep in mind is the weld or "fill material" will almost certainly be a different alloy than the original cam, making for uneven wear.
The only time I would even consider having a cam weld repaired would be on a turo Offy or something of the sort where a replacement camshaft would be near $8K. I'll ask around a few circles for a cam. I tracked down an exhaust cam not too long ago for less than $500.
-Nick
Owner: Bennington Motorsports www.benms.com
Sponsor for Midwest Region 944-SPEC racing series
-When was your timing belt changed or tensioned??
-Yes, I'm the crazy man that will loan out my 9201. Just PM me, I will add you to the list and get it out ASAP.
Old 12-18-2008, 08:28 AM
-Nick
500 my ass lol..i want one 150 range..the thing is this cam is only chipped at end where the seal is.
Old 12-18-2008, 12:56 PM
Will program for food
ghnat's Avatar
There is a guy on the 911 board here called camgrinder - he would know...
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 12-18-2008, 06:04 PM
your average wrencher...
try www.paeco.com out of birmingham AL
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 12-18-2008, 06:09 PM
i ordered one for 150 BIG THANKS TO 944online..and thanks for everyons help..
Old 12-18-2008, 06:45 PM
NineFourtyFour's Avatar
I can't see any reason that you can't have the shaft refurbished...I have had the same process done to several spindles of the CNC grinders that are used to manufacture camshafts, and they have run for years 24/7 without fail well within tolerance.(and I am having my crankshaft welded back to size currently) I could recommend a shop here in ON if you like...
Hope yu get it back on the road soon
85.5 well kinda...waiting for my engine rebuild...maybe for Christmas?
Old 12-18-2008, 06:49 PM
Redline Racer
HondaDustR's Avatar
has anyone tried any of their 944 cams? The price certainly isn't too bad.
Looks like they will weld lobes for $50 each.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
it would be nice if i can get this one fixed...like i said it only the end about half the sealing circle is chipped off...the only problem i would have if i used it is leaking some oil,i am guessing minor..i think..
Old 12-18-2008, 07:36 PM
Redline Racer
HondaDustR's Avatar
who here doesn't leak oil??
If it were me, I'd give that paeco place a call and see if they could fix it, and probably for alot less than trying to source another used one.
Old 12-18-2008, 10:37 PM
JoshB's Avatar
You sure you ordered the right one? They are asking $600 for a cam for a 944 S.
http://www.944online.com/cgi-bin/ASI_Store.cgi?Product+skukey_1137432312+944s+engin ecylinderhead-944s
91 944 S2 white/blk
Old 12-19-2008, 08:31 AM
SolReaver's Avatar
Sealing circle?
It is not chipped on a lobe? AND it is not chipped in a load bearing area?
If it is just where an oil seal rides......Cold Bond and a file.
Post a pic so that I can be sure what you are talking about.
If no pic, describe your defective shaft...............Boy, that sounds weird!
Old 12-19-2008, 08:36 AM
i had a 924 cam redone from paeco, and enjoyed their product. prices were okay, they even resurfaced my lifters and I had ordered aluminum retainers for the springs.
Old 12-19-2008, 10:22 AM
Zero10's Avatar
Send a message via ICQ to Zero10
Seriously man, when you start a thread give us some bloody information.
Pictures would also be a good idea. If you just say "chipped camshaft" it could be a lot of different things. I don't know if you think it is fun to just make a 1 line post and waste everybody's time or what. Then you continue to confuse the issue "I bought a new one" followed by "it would be nice to just get this one fixed"...? Gonna put in 2 intake cams are we? That said, its not until the 4th post by you that you even mention it is an S, so it has 2 cams, so people offering up cams are probably offering 8V cams. That also makes the cams more rare and more expensive, making pricing advice irrelevant if people don't know it is a bloody 16V motor.
/rant
2010 Hyundai Elantra Touring, GLS 5 speed, Indigo Blue Metallic. 2.0L of Korean fury!
Buy my parts!
Old 12-19-2008, 10:44 AM
/rant
my only question was if camshafts are repairable ..wat dose it matter if its 8v or 16v..i was nothing making this in to a wanted ad thats why i posted another threat in the buy sell section..heres a pic anyway
..Image and video hosting by TinyPic
Old 12-19-2008, 12:36 PM
