oil additives - zddp
I'm looking for a readily available additive to get the zinc/zddp up for my winter (Canadian winter) weight oil
Question - is anyone here using or have opinions on ZddPlus? (hard to get from where I am); GM EOS? (a bit inconvenient but not that hard to get); or Lucas Oil TB Zinc? (easy to find)
Warren
'87 944S
"Tubes sound better"
Old 12-23-2008, 08:52 AM
Sorry, I don't have experience with the two products you mention. However, I heard of these folks through the Hagerty Insurance magazine and run this stuff in my 924.
http://www.cam-shield.com/index.html
Don't have a lot of experience with it but it is fairly inexpensive and readily available.
No affiliation..., etc...
Old 12-23-2008, 09:25 AM
flash968's Avatar
don't they sell it here? they are usually pretty good about having all the cool stuff
if not, i know that rs barn sells ZDDPlus - they started doing it ever since mobil 1 changed their formula
Old 12-23-2008, 09:38 AM
your average wrencher...
www.bradpennracing.com/ out of bradford PA
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 12-23-2008, 10:15 AM
Send a message via AIM to bjd34
I use ZDDPlus from lindsey racing in my 944 N/A and 944 Turbo. I thought this was interesting
www.bobistheoilguy.com
Old 12-23-2008, 10:16 AM
The oil guy stuff is interesting. I read the Lucas Oil Stabilizer "test" he did.
The Lucas Oil TB Zinc worries me a bit, because their marketing blurb says it contains some of their "stabilizer" additives as well, and I don't really want any of that stuff in my car.
I did some more Internet searching and found Redline has a ZDDP additive now, and the pricing seems quite good. Redline stuff is sold at a lot of places in Toronto so I'll probably go with them.
Warren
'87 944S
Old 12-23-2008, 02:47 PM
Redline Racer
HondaDustR's Avatar
I would go with an oil that comes with the correct levels of ZDDP, like the Brad Penn ^^^.
Adding stuff to oil can be kind of complicated, since oil is formulated with some additives to stabilize others, and to counteract the chemistry that results when stuff like zddp breaks down over the life of the oil. Search for "the ultimate oil thread" and somewhere in the depths of it, this point is brought up a couple times.
here it is.
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
1987 silver 924S 210k mi! - Rebuilt motor survived 60K so far. Bottom end balanced, Custom mild ported head, Port matched intake, LR 944MAX chip, Thush Welded muffler, Bilstein shocks, MSD Blaster 2 coil, ect ect...Needs 8 more valves!
2003 Hyundai Tiburon GT 2.7 V6 24V DOHC- New toy/backup plan...Borla cat back, Injen intake. Needs headers and a real set of cams.
Old 12-23-2008, 05:29 PM
If everything that you guys can get easily in the States was as easy to get in Canada...
But, I found this thread from the beginning of the year about there being a Brad Penn distributor in the Toronto area
http://forums.pelicanparts.com/canada/398063-brad-penn-update.html#post3825945
and some local NAPAs carrying it
so assuming local supply is good, Brad Penn it is
Warren
'87 944S
Old 12-24-2008, 07:42 AM
zddp
check out www.camoils. They make a 15W40 high grade mineral oil with over1600ppm of zddp. Remember that racing oils do not have all the detergents required for a street driven car and may cause a sludge build up at the rings.
Bob
Old 01-01-2011, 03:39 PM
Porsche 944S Club Sport
guru944's Avatar
Send a message via AIM to guru944
Please read 10w-30 or 10w-40 winter post
Not recommended...
Also clogs Cat conv and oil Filters...
later
Guru944
2006 955 Cayenne S Titanium Series - Marine Blue, 1987 Porsche 944S Club Sport.
1987 Buick Turbo-T Lightweight "Great White", +500HP, TA49 Turbo.
http://www.blackbirdmotorsports.com, 944/951/968 & 911 Performance Solutions.
Thank you Lord, for your Loving Kindness, Tender Mercy, and Grace. Only You are Faithful.
Old 01-01-2011, 07:53 PM
novice
i have an 88' 951 and i live in new jersey. i have tried mobil and redline which has zddp. I feel like redline has an advantage in terms of the smoothness of the engine so that's what i'm running my car from now on. and the price is right. although, i want to try brad penn down the road. ..
Old 01-02-2011, 12:29 PM
