North Coast Cab's Avatar
Traqnny Removal Help
Ok, I am stuck. Everything is disconnected, but I can not get the coupler in the bellhousing to slide. Both bolts are loose in those two square bracket. I have tried to pry against it in both directions to no avail. What am I missing?
1985.5 944 GTS
Old 12-26-2008, 10:21 AM
Custom User Title
mikepellegrini's Avatar
There are notches in the driveline where the coupler bolts fit. You have to take the bolts all the way out to move the coupler.
83 944 NA - Black on black
86 951 - Red
16 Ford Expedition
He who hesitates is lost.
Old 12-26-2008, 10:35 AM
you also need to jack and level for straight off removeal. I usually need to shack and pry alot.
Also shift coupler,Cv's and backup light contact disconnected.. right..
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 12-26-2008, 11:09 AM
Both bolts are all the way out. The tranny jacked level and seperated about 1". I pryed so hard on the coupler the square part on the tranny side broke off the shaft. I have PB Blasted and just can't get the coupler to budge.
1985.5 944 GTS
Old 12-26-2008, 12:36 PM
Is the Gear in neutral?
It can get loaded which makes it more difficult remove.
Is the shifter linkage all the way pushed forward and rotated 180 toward bottom of engine, in the shifter boot.
Look back though http://www.clarks-garage.com/ trans03, removal procedures.
Did you remove the Fuel Filter Bracket from top?
Old 12-26-2008, 02:54 PM
Custom User Title
Yeah, my guess would be that somehow, there's some lateral strain on the driveline - the transaxle isn't perfectly level compared to the torque tube, or something. If the bolts are out, it should slide easily on the splines.
86 951 - Red
16 Ford Expedition
Old 12-26-2008, 03:01 PM
Got it. Called a pro Porsche mechanic for guidance. Rebolted the bell housing and tranny mount. Used screw driver from TT side through small hole and it puched right out.
1985.5 944 GTS
Old 12-27-2008, 09:37 AM
Redline Racer
HondaDustR's Avatar
Damn, I wish I knew that! That thing was really the only positively miserable part of the job.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 12-29-2008, 04:22 PM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
mee too
THAT would have been nice to know. I broke my coupler and it delayed the job for over a week. Why the hec can't this stuff be added to Clarks or something? This little tidbit could have saved me Hours under the car and days waiting for Mr. Postman.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 12-29-2008, 07:37 PM
