rob c
comicbook8@gmai's Avatar
antilock warning light
hi all ,
the antilock brake warning light has appeared on my last two trips. first the brake pad sensor light is showing for bout a week now.pretty sure its just a broken wire on the brake pad sensor circuit as the sensors are not fitted the wires are just twisted together, the antilock light went off when i stopped the engine and restarted drove home no prob but today came back on and stayed on no matter what i did . anyone know where i should start to look or if the brake pad light is related . thanks
HAPPY CHRISTMAS TO YOU ALL !!
Old 12-14-2008, 01:03 PM
rob c
when it comes to brakes its hard to give an answer i know .its not something anyone wants to be wrong on , but any ideas throw them out there give me something to chew on, besides turkey !!!!!
Old 12-15-2008, 10:35 AM
My ABS light used to come on when i hit a bump. I had to replace the wiring harnesses that connect from the body to the wheel hub harness connector. The wires were frayed and in bad shape. The harnesses are not inexpensive, and are getting hard to come by.
Keith Belcher
'87 951 nautic/cancan
Old 12-15-2008, 01:14 PM
rob c
tks i will have a check on them , my light comes on as soon as i first hit the break pedal . . .
Old 12-15-2008, 01:32 PM
rob c
anyone know where the sensor for a.b.s is situated in the caliper ?
Old 12-29-2008, 03:27 AM
The abs sensor is on the spindle. It is basically a magnet that pulses as the reluctor ring rotates with the hub. The wiring harness is combined from the strut to the body connector. The connector on the strut is where the abs and brake pad wear sensor separates.
Keith Belcher
Old 12-29-2008, 10:25 AM
rob c
cheers bleu , i know exactly where you are talking about tks
Old 12-29-2008, 03:58 PM
rob c
seemed to have found the problem !
took out the relay for the a.b.s sounds very rattly inside put it back in took it for a drive no warning lights appeared !!! new relay needed me thinks
Old 12-31-2008, 08:34 AM
