Rear caliper sliders
One of my rear brakes was squeaking, but the pads were fine. I pulled the caliper off and seperated the 2 parts of the floating caliper. Looks like it was hanging up and not sliding/floating, not sure if it was from the rust and grime or because the little nylon sliders are worn out.
![]() ![]() Anyone know how far above the metal they're supposed to stick up? Or if they are really necessary at all if I grease it up good? Also, can replacements be bought? All I found is the whole caliper kit here on Pelican, but all I need is whats circled.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy My Website: http://www.TrackPics4Less.com Last edited by 944Spec_bound; 03-21-2009 at 06:16 PM.. |
I believe mine didnt' stick up any further than the metal. They were flush, if I remember.
You can clean up the rust with careful use of a file, the nylon or teflon pieces should be included with a rebuild kit, they should stick up slightly above the casting.
Good Luck
Jeff Laurence, '87 944S |
I know the sliders come with the rebuild kit, I don't need the whole $22 per wheel kit. I just wanted to know if the sliders can be bought seperatly. Thanks.
84 Red 944 NA - Das Swurvenwagen - still street legal but it's just a track toy My Website: http://www.TrackPics4Less.com |
I have never seen them separately. But while you have it all apart, why not rebuild the entire calipers?
You'll be happy you did........
Plus, I had to get it done asap, couldn't wait to order a kit. So I just cleaned em up, lubed the sliders and reassembled, back on the road and working great now. We'll see how long it lasts though.
