DSPTurtle's Avatar
Brake Bore Question
Hi Pelicans...
Quick question on a brake caliper rebuild. Is there a spec on how "bad" the bore can be before it should be replaced? I have a spot at the bottom of the bore that is pitted beyond 1000 grit sandpaper cleaning. I ran the piston down in the bore and it moves smooth, but before I put this all back together I want to make sure that this is not going to be a failure in the near future... RBF600 is not cheap to keep putting back in the system
The pieces...
The culprit...
The question...
Thanks in advance for the quick double check!!!
JB - BreitWerks
www.breitwerks.com
321-806-8664
Engine Rebuild & Restorations
Old 01-11-2009, 12:03 PM
