Lsd?
How can you tell if your car has a LSD? (in my case an 87 924S)
'87 Guards Red 924S - First Porsche - SOLD 5/21/10 '67 Red VW Beetle - Restored by me and my dad, 2115cc motor. ![]() '87 951 - Silver/blk, full leather interior - LR Chips - 3 bar FPR - LBE '92 Ford F150 - Winter truck '04 Yamaha R6 |
jack up both rear wheels and rotate one wheel by hand. If the other wheel goes in the same direction you have a limited slip if the other wheel goes in the opposite direction you have an open rear end.
ahh thanks. I'll definitely be trying that
The "S" should definitely have LSD. The easier way to test it is to see if you leave two black strips or jut one after a burn out
JB - BreitWerks www.breitwerks.com 321-806-8664 Engine Rebuild & Restorations |
although that's no guarantee. u can make 11's with an open diff too. it's just trickier.
the above mentioned "in the air" procedure will only work on a clutch type lsd - it will not work on a torsen type - i have no idea what the 924 came with
That Guy
And it would have came with a clutch type, same transmission as all the other 8v n/a series cars. The clutches wear out and if really bad, both wheels will not spin in the same direction. The 100% positive way to check is to look at the code on the top of the transaxle bellhousing, the prefix is 8Q (early trans) or 7V (late trans).
Jon 1988 Granite Green 911 3.4L 2005 Arctic Silver 996 GT3 Past worth mentioning - 1987 924S, 1987 944, 1988 944T with 5.7L LS1 |
Or option code number 220
Twin Cammer
To add to the above post..
If you have your original owners manual, open it up.. There should be a sticker with the cars info and options on it.. if you see 220, then you have LSD.
Kev Schofield 1987 944S and a 1986 951 1984 944 sold in '09 1983 944 sold in '03 1986 944 sold in '99 |
My 944 didn't have the LSD option 220 code but I did have an LSD trans so someone added it along the way.
ahh thanks. I do have the original manual, but it's somewhere around 4 degrees right now and i dont feel like running out to my car (yes she has to sit outside
the 930 and the bug get the garage ) so i'll check tomorrow
White and Nerdy
I've got a LSD transaxel wit a code that doesn't match any 944 NA or Turbo code, not sure what it is. Is a bit long legged for an NA in city traffic, but the gear ratios fit me once I'm moving.
Shadilay. |
Locks are frozen today...can't even get in the car to check the manual....
Quality
Is the car supposed to be in gear, or not, for the wheel spin test?
85.5 944 NA 5spd - Sold but not forgotten 89 951 Turbo S - Revival in progress...
Doesn't matter if in gear or not.
