Enthuzed1's Avatar
Location: Sometimes Sacramento, Most of the time Concord, CA
AC Condenser and Electrical Gremlins
Hello all, I don't use my air conditioning nor do I plan on doing so. My AC condenser is trashed from a previous mishap concerning my car an a center island. Just finished putting the car back together and I'm not putting back the condenser. Will it affect me just using the air or the heater? Can I cover up the hoses or will that affect blowing air into the car? Also my wipers still keep coming on randomly whenever my headlights are up. I've resorted to removing the fuse at night if it's not raining. Any suggestions? Thanks so much!
1987 944 Naturally Animalistic
"If you make the same mistake twice, doesn't that make a total of three mistakes?"
Old 01-14-2009, 12:14 AM
Enthuzed1's Avatar
bump
Old 01-14-2009, 04:18 PM
Just thinking out loud
mattdavis11's Avatar
The condenser being removed will show a net loss in radiator temps. There are no adverse affects if you don't need the a/c, unless you need card board to get the heater going.
91 FJ80
84 Ram Charger
Old 01-14-2009, 07:47 PM
Overseas
It will have absolutely no effect, no card board will be needed, the cooler will work just fine.
Just plug the A/C hoses well, so that no water gets inside.
BTW, what kind of car is this? As if it's an early one, and you'd consider taking out the A/C inside uint and the hoses, I'd be interesed in buying them. If it's a lte 944, maybe then too
Tomiki
924S (1986)
Old 09-04-2009, 09:14 AM
