PRMN944
1983 944 Fuel gauge
Does anyone know what happen to the fuel gauge? Whenever I exit the ramp or turn a corner the fuel needle indicator wonders off and does not come
back to normal.
It works fine when I fill up the gas tank. Although, I replaced the whole combo
gauge 2 to 3 times with used ones.
May be it is time for new one?
Old 01-21-2009, 02:02 PM
maybe it's your sender that's sticking and not the gauge?
also check the wiring and the grounds.
Old 01-21-2009, 02:36 PM
Let's go shooting.
Dark Skies's Avatar
back to normal.
That's definitely your sender. You can take the early ones apart (carefully) and clean the fine wire and sender bobbin that runs along it so's it doesn't stick. I think there's a how to on Clarkes for this.
1983 944 Lux (manual) 2.5 litre 8 valve na and no pas
1991 944 (automatic) 2.7 litre 16 valve na and pas
"I have only five words for you: From my cold, dead hands."
Old 01-21-2009, 05:33 PM
PRMN944
When it happened , I replaced the fuel sender several years ago. As right now,
to keep the fuel needle gauge working at least normal I have to maintain
the gas in the tank above 3/4 level.
Thanks for the advice.
Old 01-23-2009, 02:37 PM
Mountain Road Maniac
ColoradoSteve's Avatar
I had similar weirdness with my '83 gas gauge and replacing the sending unit didn't help.
I took the thing apart and cleaned the contacts, now it works fine.
'83 944
'87 951- SOLD!
Old 01-23-2009, 08:13 PM
Just thinking out loud
mattdavis11's Avatar
Mine's iffy. The idiot light works, and I have anther 70-80 miles if it comes on. That's what works for me.
It's been that way since 1992.
91 FJ80
84 Ram Charger (now gone)
Old 01-23-2009, 11:37 PM
Proprietoristicly Refined
John_AZ's Avatar
There are a couple of cleaning procedures you could try. This one is in our Tech Section (radio button ^)
http://www.pelicanparts.com/techarticles/911_fuel_tank_sender_replace/911_fuel_tank_sender_replace.htm
OR the simple suggestion:
http://www.924board.org/viewtopic.php?t=24372&sid=7183fc4caee197fed1f20177df325190
Have a gasket on hand before you start if you take it out.
GL
John_AZ
Old 01-24-2009, 05:26 AM
