Phone Dial ?
I know this has been answered before. Looking at some wheels off and 87. Guy claims they are 15x7 and 15x8? Doesnt sound right. Also would that offset work on my car?
Old 10-13-2009, 10:20 PM
Garage Helper
Cocacolakidd's Avatar
Send a message via Yahoo to Cocacolakidd
15x7 and 15x8 can be correct.
Look on the back side of the rims - all of the facts should be there, rim size, rim width (usually stated in J's, ex. 7j 15 would be a 15" rim at 7" width) and offset is there also.
The 87 has the late offset rims - your 1986 944N/A is the early offset - to use these rims you will probably have to have 1" spacers
Early offset is 23mm - late offset is 52mm
78-924 traded for 80-931 traded for 84-944 traded for 85.5-944 (7th one now).
UAV-M1 (Urban Assault Vehicle - Model 1)
Bless the lowered, and pass the nitromethane.
Pedal to the metal till you see the gates of hell then brake
NLA - No longer available is a four letter word
Old 10-13-2009, 10:36 PM
I know I can look at the back. I just was wondering if what he was telling me is true... They are about 3 hrs away.
Old 10-13-2009, 10:51 PM
Garage Helper
Have him tell all numbers on the backside of the rims - different numbers on the front rims and different numbers on the back rims - rim width and offset is different on front to rear. If they did fit his 87 they will be the wrong offset for you - again may have to use spacers - unless they are early offset and stuck out allot on his car.
Old 10-13-2009, 10:55 PM
TSNAPCRACKLEPOP's Avatar
that is the stock phone dial wheel size on my 1987 944 na
chance favors the prepared mind
1987 944 n/a 5spd. who remembers dial phones?.
'STOP FIXING THINGS ONE STEP BEFORE YOU BREAK SOMETHING ELSE"
Old 10-14-2009, 09:27 AM
Hmmm... The more I think about it I may pass... If I have to swap on spacers they will be too much hassle to used as track wheels...
Old 10-14-2009, 10:08 AM
less hassle if you get them and give me the center caps, you would not have to worry about loosing them.
Old 10-14-2009, 10:11 AM
Haha right.... I already have one spare set of center caps....
Old 10-14-2009, 10:22 AM
Garage Helper
If you are looking for track wheels go with the Fuchs - they they come in the 15-7's and 8's also - they are half the weight of the Phoney's and with the early offset
Old 10-14-2009, 11:25 AM
