No cabin heat 1985.5 944
Car has no cabin heat changed the thermostat bled the cooling system and still no heat even with the engine heating up to the middle mark. I was wondering if that heater control valve my be my problem it's cold here.
I would agree that is your problem. You should be able to disconect the vaccum line and manually move it into position to test.
Good Luck |
I'll give it a shot car was blasting heat last week it's a bummer as both project cars fill the garage. The joys of winter working on your car when it's -5 with over 20 centimeters of snow falling great day to be a kid it's a snow day.
Mine ended up being the clip under the drivers footwell.
Oscar |
