trailpimp33's Avatar
Clutch Help!!
I have an 83 n/a that I am working on. Here is the issue, I thought that maybe the master or slave were going out as the pedal would travel down about 2" with only a tap of the foot and you could then feel it make contact with the master, then it would not return all the way, stopping at the 2" mark. I checked the master, slave, and lines for any signs of leakage with none to be found. When I checked the floorboard for fluid I also found NOTHING. What I did notice though is that the plunger for the master is NOT making contact with the piston until it goes through that first 2" (at the pedal not the master) of travel. The piston seats against the c-clip, it just seems as if the plunger is not long enough or there is something missing at the end of the plunger. I have the plunger rod adjusted as far out as it can go so that is not the issue. Should there be anything at the master side of the plunger or does it simply rest in that bore?
Old 01-24-2009, 06:14 PM
Quality
phoenix_iii's Avatar
Original parts? Miles? Are you having any actual problem?
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 01-24-2009, 09:48 PM
PRMN944
You can try to bleed the clucth system if that works for now.
If you see brake fluid leaking around floorboard then it is too late.
May be it is warning sign for master clutch failure.
Old 01-24-2009, 10:54 PM
Redline Racer
HondaDustR's Avatar
There is nothing that connects to the master cylinder. It's just the rod with the rounded end that just sits inside the cup shaped recess on the MC piston and should be just barely touching it. If you pull the rubber dust boot off, you should see the piston fully retracted right up against an internal C-clip on the end of the bore closest to the pedal. If it's further inside, either some springs are broken, the piston is binding, and/or there's a bunch of air in the system that prevents the clutch pressure on the slave from forcing the master piston back, but it has a pretty heavy spring inside that should return the piston on it's own.
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 01-24-2009, 11:13 PM
The piston seats against the c-clip and retracts no problem, that is what is throwing me. The master looks good, I am starting to get suspicious that the PO used a part from some other car.(non 944) The master looks good, just that plunger seems like it is not long enough, or the master does not come through the fire wall far enough.
Any other ideas???
Anyone have a spare clevis and plunger from an old swap laying around?
Old 01-25-2009, 12:42 AM
meister member
speedracing944's Avatar
you need to bleed your clutch. Lift the rear high in the air and use a pressure bleeder.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-25-2009, 06:49 AM
Redline Racer
HondaDustR's Avatar
Guys, it sounds like there's a mechanical discrepancy here. I'm not sure air in the system is the problem just yet. If the actuating rod doesn't even reach the MC properly, it's not going to work, bled or not.
Do you have a picture to show exactly what's going on? It could be a wrong part somewhere.
Old 01-25-2009, 09:25 AM
There is adjustment on the rod and before the rod there is a spring. Do you have both of these?
Old 01-25-2009, 09:46 AM
The rod is adjusted out as far as it will go, and yet still does not make contact with the pocket in the piston until the clutch is depressed a bit. The master and slave do NOT need to be bled, the piston in the master is bottomed out on the c-clip. I will try and get some photos tomorrow.
zedsn, what spring are you talking about? On my car there is the pedal, to which the clevis is attached, then the rod which is threaded in the clevis, and the rod then makes contact with the piston in the master.
Old 01-25-2009, 08:16 PM
Hi, above the rod higher up on the other side is a pre load spring. Is yours there? Get yourself a Haynes 944 shop manual and it gets into a little detail on adjustment.
Old 01-26-2009, 03:58 AM
Well, I found out the problem...
Cracked and bulged firewall!!
Anyone have a good fix for this one??
Old 01-29-2009, 07:52 PM
Ouch. Isn't that master cylinder like, way up there?
Old 01-29-2009, 08:33 PM
