Rockin' NW Arkansas
firefighter7128's Avatar
Send a message via Yahoo to firefighter7128
Rear Axle swap-out
I have some good complete axles that need to go on my car. Anyone ever do this? looks as easy as just pulling a few bolts but im not going to fall for that. Suggestions, Tips, tricks?
Matt
1986 Porsche 928 S - Daily Driver
1984 928 S - SOLD, 1986 944 S - SOLD, 1988 944 S - SOLD
Old 01-30-2009, 03:45 PM
smlporsche's Avatar
Check Clarks Garage for a write up on how to do it.
The bolts take a special tool ...
Old 01-31-2009, 06:00 AM
drunk and stupid
HHI944's Avatar
I just bought the tool (actually a set of 6,8,10 and 12mm) off Amazon for $10 shipped, just search 'triple square'. Seems to be the cheapest price.
Old 01-31-2009, 07:00 AM
meister member
speedracing944's Avatar
If they are triple square (AKA cheesehead) bolts, do not try to use allen head tools or they will strip.
Speedy
1983 944 guards red with 16" Fuchs, Host of Wisconsin area timing/ balance shaft belt tensioning party
1987 944S Purchased from Legion. Corvette LT-1 V-8 conversion with Mega Squirt II
Check on progress ---> www.porschehybrids.com/gallery/speedracing944
Favorite Road = www.tailofthedragon.com 318 turns in 11 miles (11 min 20 sec best run)
Old 01-31-2009, 08:18 AM
smlporsche's Avatar
I just bought it from Pelican.
Figure it was good to support our forum and I'm hoping that the quality of the bit will be very good.
Old 01-31-2009, 08:22 AM
That Guy
Techno Duck's Avatar
If your in a bind and have a Pepboys around or any place that carries the 'Performance Tool' brand, they should stock the triple square drivers also. They are not the best quality, but are reasonably cheap, so pretty much disposable after a one time use. The head on the ones i bought started to twist a little after doing the CV's on my friends car. I ended up buying a good quality set for the tool box. But not a bad option if you need them quick.
Those bolts can be a real pain in the butt. If they are dirty, spray the heck out of them with brake cleaner and make sure the head of the tool is seated completley before you apply any torque on them or they will strip!
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 01-31-2009, 09:42 AM
Custom User Title
Dave L's Avatar
Be sure to clean out the gunk in the bolt holes, you dont want to strip one of those bolts. I blasted mine with WD40 and that cleaned most of the gunk out.
Old 01-31-2009, 09:45 AM
I added a little more torque to the process with a set of vice grips. pushing on them and the triple square tool at the same time got the stubborn bolts moving without stripping anything.
'87 924S 5sp
Slowly recovering from a warped head
Old 01-31-2009, 11:54 AM
Rockin' NW Arkansas
do the wheels need to come off? i bought the tool for $11.99 at autozone locally. I assume the car does need to be raised as well
Matt
Old 02-01-2009, 11:54 AM
