Fuel rail to Gauge adapter
Do you guys know who sells them? or how can one be made?
I've got a gauge that i would like to attach to my rail. Thanks
Dan '84 944 - Under construction '77 924 - Sold '05 Jeep Liberty '98 Acura Integra |
I'd give Lindsey Racing a call and they could probably help find you the correct adapter.
http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LR&Product_Code=LR-FPGK
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles |
I did mine using local hardware store stuff. I don't remember the exact sizes. sorry
Sid splitting my obsessions with a crow bar. 87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127 |
winter-hater club member
there are some on ebay, usually.
2000 Corvette - ????, 2007 Buell XB9R - Astrid, 1996 Discovery - Piglet, 2000 Forester "COOL PRIUS!" - Nobody Ever |
Politically Incorrect
Edek '87 924S '91 535i |
I'm going to try to make my own adapter as well.
For those wondering, the size for the fitting is 12mm x 1.5 on the fuel rail. Supposedly the fittings to make an adapter can be found at ACE Hardware so I'll be trying that soon.
'87 944 |
I had a hard time finding the right sizes at the local parts stores, so I got a new cap ($6) and had a local guy drill, tap and braze an adapter to the end of the old cap ($10). If you can do the work yourself great, if not, I'm sure someone local can help.
Current: 2014 Jetta SE 1.8L Turbo 2001 Civic 4 door, totaled ![]() Red 1985.5 944 NA sold Maroon 1985.5 944 NA sold |
Check out http://www.clarks-garage.com/ under the shop manual section they've got the instructions to make an adapter.
I made mine using their instructions. The hardest part was finding chunk of scrap metal to drill out.
Life's short Go fast Have a blast Leave a good looking corpse in a 84 944 |
I just use mine to check the pressure if I have problem. I simply removed the cap and hose clamped the hose over the fitting. After doing so, piull on it pretty good to make sure it is tight. I would not use set-up for a permanent gauge connection.
Learned by do'n twice
The easiest, cheapest, and the solution I use:
A 6" section of rubber hose of the appropriate size with a gauge stuck in one end and hose clamps holding the gauge and the fuel rail on. jmd_forest
86 944 NA - Brought back from the dead |
