thoen's Avatar
WHeels and Weight Question??
I recently replaced my OEM 15" Fuchs with OEM 17" Cups. I know that the cups are heavier but HOW MUCH HEAVIER???
Does anyone "wheelie" know the difference in weight??
Yellow 1983 944. Many alterations, modifications, repairations and aberrations. Great car!!
Old 02-01-2009, 05:19 PM
flash968's Avatar
well, as there is a varying understanding on what is a "cup" wheel, and a good amount of misinformation about this, it's hard to answer that - the only wheel porsche actually used the term "cup" on was the 993 Cup - all of the other designations using that term are misnomers - you can see the correct designations on the wheel enhancement site
but to answer the question, the 17" wheel that came on the early 968 is a C2 Turbo - the 17" wheel that came on the later 968 is a 993 Cup - the weight is about 25lbs rear and 23 lbs front for the early and 23 and 20 for the late
the thing to consider is also the weight of the tire - you can easily gain more weight there than from the wheel - tire rack has a fairly complete listing of tire weights
Old 02-01-2009, 10:37 PM
Tam Lin's Avatar
Click on "Felgen" then "Tabelle" if this does not open correctly http://944racing.de/reload.php?urltogo=http://944racing.de/felgen.html
924S 1988 KW3 v3, Wilwood brakes, and a diet. Oh and a 3L 16V drivetrain
Old 02-02-2009, 04:44 AM
I went from 15x8 fuchs running 245/50 Hoosier R6's to 17" "cups" running 275/40's R6's. The weight increase was 12lbs per wheel
Tim
'95 968 (Daily Driver)
'87 944LS (track beast)
Old 02-02-2009, 09:18 AM
flash968's Avatar
ouch - that's an effective gain of 192lbs on the car, after factoring in the rotating mass - that's the kind of gain that is easily felt in every aspect of driving, from braking to acceleration to how the suspension acts
i'm still hunting for the perfect set of 17s so i can drop a few pounds - i am torn between what is super lightweight but hard to keep clean and what is a bit heavier but easier on the maintenance - tires are the real hangup though - nothing available in the profile i want in a 17, and i'm not sure i want to give up any of the grip i have now
lol - i've been riding this fence for a LONG time now though
Old 02-02-2009, 09:31 AM
I needed more brake and more rubber on the road, the only way to do that was with bigger wheels. We will see if it turns into reduced lap times or was a waste of money in early March.
Tim
Old 02-02-2009, 10:03 AM
thoen's Avatar
thanks guys. I learned a lot!!!
Old 02-02-2009, 10:19 AM
flash968's Avatar
lol - it is a never ending circle isn't it? need more brake and more rubber - get bigger wheels - now need more brake and more power to make up for that - going faster now - now need bigger suspension to handle bigger loads - now need more brake again......................
Old 02-02-2009, 10:26 AM
Factoid: I recently weighed a turbo twist with a pirelli 255/45/17 (?I think) and it was about 55lbs.
Another factoid: 225/50/15 toyo on a cookie was 34lbs.
Old 02-02-2009, 02:16 PM
thoen's Avatar
e moore,
those numbers match what i thought. when i picked up the fuch tire/wheel, it was easy. Picking up the cup tire/wheel is another story. so we lose some horsepower/weight ratio just so that my eyes are pleased. i guess it is worth it...now....how do i add some more HP? i have done nearly everything, cold air intake, MSD ignition, bursch headers, berry chip...all of it lost to the extra weight of the cups???!!!!
Old 02-02-2009, 02:24 PM
White and Nerdy
Tervuren's Avatar
Look in the recent picture thread, the 17" wheels on my car are 7.5's and 8.5's, I believe front with tire was shy of 50lb's, and rear with tire was just over. They are wheels by an Australian company called ROH.
Shadilay.
Old 02-02-2009, 02:30 PM
White and Nerdy
Tervuren's Avatar
Wheel and tire weights for my 17's are actually 43.lb's. front and 49.5lb's rear.(205/50/17, and 255/40/17).
Shadilay.
Old 02-02-2009, 04:36 PM
flash968's Avatar
that is about right for a 993 Cup wheel and a half worn tire
Old 02-03-2009, 06:44 AM
Damian in NJ's Avatar
Thoen, you never said if you have Cup 1's or Cup 2's.
95 968 Cab, Speed Yellow, Kinesis Supercups, Promax chip, Big Reds, SS brake lines, 5/35 brake bias valve, H&R sport springs, mo30 sway bars, LSD, Brey Krause control arm brace, Dynatech billet strut brace, Cargraphic 100 cell cat and ss exhaust, Club Sport steering wheel, short shift, sport seats
Old 02-05-2009, 01:13 PM
