-   -   Speed Reference Sensor and Tach Bounce (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/455823-speed-reference-sensor-tach-bounce.html)
944_science 02-21-2009 01:10 PM
I actually started a new thread on the injectors.
http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/457608-cleaning-injectors-advice.html
If I still have issues with them I will definitely consider someone local though, good idea I hadn't thought about.
SpidrVII 05-15-2012 05:38 PM
Same Part Numbers for Sensors?
Originally Posted by Outback Porsche (Post 4479533)
8(25)-27(26) should be 0.6 to 1.6k Ohm, and
8(25)-23(78) should be more than 1M Ohm.
Replace your sensors.
Beamer ones are half the price.
Hello,
What model and year BMW are you speaking of? From what I've seen, the P944 Bosche # is: W0133-1608773 Manufacturer number: W0133-1608773
AND/OR:
BS0261210003 Manufacturer number: 0261210003
While the BMW Bosche # is:
BS0261210002 | Mfr #: 0261210002
AND/OR
W0133-1613778 | Mfr #: W0133-1613778
Could you please clarify?
Thank you
Outback Porsche 05-15-2012 06:19 PM
No worries,
My '83 has been running with BMW 633CSi(09/81-84)/635CSi(1985-05/87) sensors since 2008. I paid about $70USD each I think.
Pelican part number is 12-14-1-708-619-M14. Sorry don't know the bosch number off the top of my head. I may still have the box with the old originals in it at home. I'll have a look when I get home from work this arvo.
Cheers
John_AZ 05-16-2012 06:38 AM
Optional Bosch number 0.261.210.002 ----sensor with slightly longer wire.
The 944 OEM Bosch part number is 0.261.210.003
Pelican sells the OEM sensor with the silver metal cap on the end or the cheaper version -all plastic black.
Pelican Parts - Product Information: 944-606-115-00-M14
Or the cheaper FAE (not often mentioned or purchased for the 944)
Pelican Parts - Product Information: 944-606-115-00-M323
John
amehl 10-16-2014 06:37 PM
Well. I dont have an oscilloscope, couldn't really do more tests. Jiggled and checked for corrosion. Everything was fine. Couldn't handle it. Last thing before I called it quits and went in side, I decide to fit the new sensor. WHAT DO YOU KNOW. fired right up. Thank god. I really appreciate the guidance! I still learned a lot about electrical nonsense so it wasn't a total loss.
kjhkjhg 10-24-2014 04:03 AM
My sensors gave me grief initally, I sprayed some CRC (light machine oil) at them then left them for a day. They came out with no effort.http://lifehealthus.com/image/images/93.gif
dhfghgfjh 10-25-2014 05:32 AM
