Porsche Crest '80 931 died, now wont start
Folks
I just purchased a 924 T and was running fine. Was idling before I took it for a drive and it just died. Now it cranks over but wont start.
I have tested the fuel pumps which are pumping at correct rate.
Replaced dist cap & rotor.
Voltage @ battery 12.8V however for voltage test Haynes manual (Ch 5 sec 22, fig 5.11 pg 132-133) there is no voltage reading to ignition control module.
All other electrical readings (resistance & voltage) seem fine .
What am I missing here. Why would there not be voltage reading to the ignition control unit?
Thanks in advance!
Old 02-11-2009, 11:04 PM
your average wrencher...
check fuses?
1982 931 *project*
1986 951 Garrett turbo, Rogue Tuned (sold)
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
Old 02-12-2009, 04:17 PM
This is kind of a lame response but I'd take this to 924.org. You're likely to encounter more expertise on the early cars, especially the turbo, over there.
Old 02-13-2009, 07:55 AM
