Fuel rail to Gauge adapter
Do you guys know who sells them? or how can one be made?
I've got a gauge that i would like to attach to my rail.
Dan
'84 944 - Under construction
'77 924 - Sold
'05 Jeep Liberty
'98 Acura Integra
Old 04-11-2007, 02:57 AM
I'd give Lindsey Racing a call and they could probably help find you the correct adapter.
http://www.lindseyracing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=LR&Product_Code=LR-FPGK
1987 924S with 968 Drive front to back, Bilstein Insert on mod/stock Struts, 450# Hypercoils, 28mm Torsion Bars, Weltmeister Adjustable Sway Bars, Lindsey 968 Light flywheel, Spec Stage II Clutch, ToYO RA1's, Auto Power Cage & 6 pt Harness, KLA Strut Brace, Greasy hands, heavy foot, and lots of smiles
Old 04-11-2007, 05:45 AM
I did mine using local hardware store stuff. I don't remember the exact sizes. sorry
Sid
splitting my obsessions with a crow bar.
87 DD Black 951 Holset HX40-35 custom garrett turbine, Ford MAF, Rogue tuned,SLM stroker, best ET 11.4..best mph 127
Old 04-11-2007, 08:38 AM
winter-hater club member
nynor's Avatar
there are some on ebay, usually.
"COOL PRIUS!" - Nobody Ever
Old 04-11-2007, 09:06 AM
Politically Incorrect
onZedge's Avatar
http://www.9xauto.com/pressure.html
Edek
'87 924S
'91 535i
Old 04-11-2007, 09:42 AM
I'm going to try to make my own adapter as well.
For those wondering, the size for the fitting is 12mm x 1.5 on the fuel rail.
Supposedly the fittings to make an adapter can be found at ACE Hardware so I'll be trying that soon.
'87 944
Old 02-12-2009, 08:13 AM
I had a hard time finding the right sizes at the local parts stores, so I got a new cap ($6) and had a local guy drill, tap and braze an adapter to the end of the old cap ($10). If you can do the work yourself great, if not, I'm sure someone local can help.
Current: 2014 Jetta SE 1.8L Turbo
2001 Civic 4 door, totaled
Red 1985.5 944 NA sold
Maroon 1985.5 944 NA sold
Old 02-12-2009, 08:18 AM
Check out http://www.clarks-garage.com/ under the shop manual section they've got the instructions to make an adapter.
I made mine using their instructions.
The hardest part was finding chunk of scrap metal to drill out.
Life's short
Go fast
Have a blast
Leave a good looking corpse in a 84 944
Old 02-12-2009, 09:12 PM
I just use mine to check the pressure if I have problem. I simply removed the cap and hose clamped the hose over the fitting. After doing so, piull on it pretty good to make sure it is tight. I would not use set-up for a permanent gauge connection.
Old 02-14-2009, 05:05 AM
Learned by do'n twice
The easiest, cheapest, and the solution I use:
A 6" section of rubber hose of the appropriate size with a gauge stuck in one end and hose clamps holding the gauge and the fuel rail on.
jmd_forest
86 944 NA - Brought back from the dead
Old 02-14-2009, 05:40 AM
