darnellsgarage
Do I need new motor mounts?
Have some unwanted vibration on initial takeoff. Idles smooth enough, the car is smooth at speed. Its just that initial take take off that it is a little rough. Clutch has very few miles on it, maybe 10k, car is otherwise running well.
What do I look for to see if mounts are shot?
Is this a job that a regular guy can, or should, do? I see instructions on Clark's - how long does it really take?
don
Old 10-18-2009, 10:37 AM
Hi Don, this s the best I can do for you right now. This will show what a bad engine mount looks like.
http://www.944online.com/cgi-bin/forum/forum.cgi?board=944tech;action=display;num=1224859 510
Cheers,
Larry
Old 10-18-2009, 01:01 PM
951' should have the solid rubber mount (as opposed to the fluid filled)? Try a search here. IIRC there are some measurement/guidelines of sub-frame to engine clearance that indicate if they need replacement from compression.
My other suggestion would be to jack the engine (with a block of wood) and see if the engine mounts separates from the base to see if the rubber has broken loose. Sounds more like what you're describing..
Old 10-18-2009, 06:43 PM
