Arizona_928's Avatar
HG queston
I'm ready to put my head back on, and am wondering if i should any sealants?
and if there is anything i should do to the threads? I have the block already cleaned so that's checked off.
thanks guys
dolor et pavor
Copyright
Old 02-15-2009, 08:57 PM
That Guy
Techno Duck's Avatar
No sealant, install dry. Wipe the head stud threads down with a light film of oil. I used WD40. Make sure you follow the torque sequence.
Jon
1988 Granite Green 911 3.4L
2005 Arctic Silver 996 GT3
Old 02-15-2009, 09:02 PM
Got Turbo?
PAUERMAN's Avatar
One of the two M6 Allen bolts that seal the water passage at the front of the head have a tendency of corroding. This sometimes results in the bolt snapping mid span upon removal which then neccesitates the need for an extractor to remove the piece stuck in the block.
The reason the one bolt corrodes is because the head gasket has a rubberized seal around the water passage section, but the seal doesn't cover the full perimeter of one of the bolts. Take a look at the pic.
I would recommend putting a small amount of high temp RTV on both sides of the head gasket in the corner (upper left in pic) creating a full rubberized seal around that bolt hole.
Vic Timpauer - www.pauertuning.com Mesa, AZ
944 Turbo S - Plug & Play Vi-PEC V44 EMS, GT3076R
DynaPack Dyno:
358whp/352lbft @ 18.5 psi 91 pump
438whp/430lbft @ 22.5 psi E85
Old 02-15-2009, 09:34 PM
Proprietoristicly Refined
John_AZ's Avatar
Levi,
Like TechnoDuck said follow the 3 step torque sequence.
To get the best results------------Let sit for 45 minutes between steps and gently tap the head before and after the step to help "set" the head.
The block surface must be perfectly clean of oil and gasket material. I used acetone.
Clean out the galleys between the cyl and block. I had crud at the bottom of the rear cyl galley. Look carefully.
The scuffed head washers should not move while torquing the new head nuts-per WSM
GL
John_AZ
Old 02-16-2009, 05:25 AM
