LinkBack | Thread Tools | Rate Thread |
86 944 went through some semi-deep water. Wont start, help would be much appreciated
Hey everyone, it was raining pretty bad and I went through a semi deep puddle. It was in a parking lot and I drove a little bit in 1st and maybe a little 2nd gear. I parked up and went about my business. When I came back maybe 30 min later, I tried starting her and she wouldn't start. I don't know whats going on, help would be much appreciated. Thanks
Jindogeh,
Years ago I used to have an 85 1/2 944 and had 2 water incidents that might be of interest to you. In one case, a storm drain clogged in a parking lot where I was parked and the car got wet. I don't know exactly how high it got, but the car wouldn't start afterwards. Turned out that the alarm computer had shorted out and was preventing the car from starting. In the second incident, I drove through some semi-deep water and then the car stalled about a mile later. It would not start for about a half hour, but then started up. The interesting thing is that the car then had a slight vibration at hight RPMs that wasn't there before. A few days later, my balance shaft belt went, taking out my timing belt, and bent a bunch of valves. Not sure if this was a fluke, but you may want to be on the lookout for it. Good luck! |
Had a similar incident here last spring. I ended up pulling my starter and at least a cup of water ran out of it. Hope this helps, good luck. J R
Feelin' Solexy
When you turn the key, does the engine spin but not catch i.e. it cranks but does not start?
It's possible that you got the belts wet and some water got flung up in the distributor area, especially if the dust cap is missing or damaged. If that's the case pulling the cap (easy to do with just a philips screwdriver) and drying the area might do the trick.
Grant In the stable: 1938 Buick Special model 41, 1963 Solex 2200, 1973 Vespa Primavera 125, 1974 Vespa Rally 200, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar, 2011 Pursuit 315 OS, 2022 Tesla Y Gone but not forgotten: 1973 VW Beetle, 1989 Porsche 944, 2008 R56 Mini Cooper S |
Check your compression. If low, you may have suffered the dreaded hydrolock.
Don't drive your 944 in water over six inches deep... it will cost you, maybe a starter, maybe an engine... it is not a boat.
Good luck, George Beuselinck |
Just curious... how deep was this water?
*1988 944 NA with front end Turbo Conversion* *1968 400 cubic inch bored and stroked Firebird* |
Could also be water ran from the battery compartment , down the wires and into the DME-- this happened to me .
Jeff Laurence, '87 944S |
Could also be that the reference sensor got wet. I had an 87 924S with essentially the same motor, every time my son would wash the car, it wouldn't start for like 30 minutes or so until. We isolated it to the reference sensor being wet. If the reference sensor is having trouble communicating with the DME, no fuel, no spark. This can also occur in cold weather where condensation builds up on the sensor and then freezes in the cold.
15 981 GTS | 88 924S SE | 82 931 Holbert | 82 931 Rallye | 81 937 | 81 Euro 931 | 81 Weissach | 80 US 928 | 80 US 931 '941' | 80 US 931 | 80 931 GTR | 79 Sebring | 78 D-Prod Replica | 78 w/D-Prod kit | 78 Poli-Form | 78 Limited Edition | 77 Martini |
Hey everyone, yea so i just got back from my car to pick some stuff up and first of all thanks for the advice. I tried starting it and it started. I let it run for a bit and then tested it to about 2000 rpm in neutral and I may be just paranoid or something(it is still pretty cold weather wise here) but I think it felt a little rougher in vibration than i'm used to feeling. Are my worries warranted?
and I think the puddle at its deepest point maybe 1ft deep. It was in a parking lot with a deep dip and I didn't see it....pretty weak. and how would I go about draining the water if there is water in the distributor cap area?(or any other area for that matter haha) |
Oh and how would i check the compression? and what would i be looking for when i find it? sorry I am relatively new to owning and maintaining this car haha
Your timing and balance belts definitely got wet. I wouldn't drive the car until they are checked/replaced. As mentioned by Jamie '92 968:
'83 944 N/A '88 Ford F-150 4WD - Does Everything '99 300M - Daily Driver, headlights just polished! '85 34' ITASCA MotorHome, built-in blender baby! '89 Supra - Black - Future 400hp NA sleeper. |
So its probably a given I have to replace the belts? probably get tow truck to where i can do that yea? and would that be the end of my worries, or are there more things i should look for before driving the car?
if throttle response is good, idling/driving it will dry it out.
87 951, K27/6, Almond Beige, 17" Turbotwist 87 944S, alpine white, 5sp died a violent death 84 944, silver/brown, auto, gone but not forgotten "may the force be with you" |
I would check the belts, the cost of not doing it is too high.
Really? 1ft. of water here goes well over the bottom of the engine in our 944. Not to mention that even with the debris shield that is still on our 944, the water would enter the front of the nose, through the radiator, and be splashed all over the engine compartment.
Water splashed on the engine compartment isnt that big a deal. Hello ever driven a car in the rain?
The issue is when its deep enough that the snorkle on the airbox sucks water in, or when its deep enough to submerge the starter....
porsche4life...yeah, I understand. Yes, I've driven cars in the rain...no, it isn't the same as driving through 1ft of water. The whole point of the timing covers are to keep debris from entering that area. They really do a piss-poor job, so my point was water can easily enter there. Some people think getting the timing/balance belts wet is just fine, others don't. It's obvious people want to argue about it, so I'll just bow out and leave it be.
^ yeah well, It's always better to err on the side of caution anyway isn't it. Water is not supposed to be in there, and belts are a lot cheaper than valves and a head job. it's at least well worth a look, open the air filter housing also and pull the filter out, see what that all looks like.
1991 cabriolet (sold) 1989 S2 1988 S 1987 944 n/a (sold) 1987 944 factory yellow (junked )
Proprietoristicly Refined
There may be some that have not seen this TSB on removing the smorkle. In AZ it is the monsoon that swells the low lying road dips. You can inprovise the "cap" with chair or walking stick rubber cups.
![]() Glad you got lucky. GL John_AZ 1988 924S + 1987 924S |
