Fuch Fitment on 1987 n/a
will original porsche fuch 15x8 wheels work on all 4 corners of my 944 without any fender rubbing issues or looking odd. Thanks, Josh
1987 944 n/a
Old 02-19-2009, 08:22 PM
Might be a little wide as far as looks. Prolly screw the handling. I have no clue if they will fit or not. I would think not being that wide. At least not on the front.
Sidney J.
1986 944N/A India Red, Well Prepared
Past:'69 Beetle, '90 Corrado G60, '97 M3
Old 02-19-2009, 10:22 PM
Non Compos Mentis
Nope.
Fuchs are early offset, your car is late offset. 8" Fuchs would rub the fenders massively from sticking out too far.
Old 02-20-2009, 02:54 AM
im gonna go test fit the two that i have and see if i can see any rubbing in my future. I really want these fuchs on my car. somebody had told me long ago that as long as they are 15'' i should have no trouble. Thanks Josh
1987 944 n/a
Old 02-20-2009, 12:49 PM
Well if somebody told you that long ago then they were wrong long ago.
Old 02-20-2009, 01:40 PM
This has been discussed many times before. I too want to fit fuchs onto an 87. Im pretty sure it CAN be done but it is a hard fit that requires camber adjustments and the right tire size.
72 914 Sold
84 944 Sold
85.5 944 Sold
78 924 (first car) RIP
Old 02-20-2009, 03:10 PM
There is no problem that cannot be solved by enough time and money.
Kind of a waste of effort, though.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 02-20-2009, 03:50 PM
mitsumark's Avatar
I can see why he wants Fuchs on his car..Thats why I'd always go for the early car...
84 Guards Red 944
88 Conquest TSI
98 Pontiac GTP
Old 02-20-2009, 07:11 PM
Non Compos Mentis
Early offset 7" wheels will fit if you use skinny tires or lots of negative camber in the rear. Not sure about the front. I've done that in a pinch, and there is no room to spare. Eights will not work.
Old 02-20-2009, 07:12 PM
i mounted them and you guys are right, none fit, not on the front or the back. I talked to a buddy and he has a bunch a bunch of early 944's. Im gonna convert my car to early offset. we pullled one of the hubs today and hes gonna pull the rest off this week.
josh
1987 944 n/a
Old 02-22-2009, 05:29 PM
jmancool's Avatar
Wow, they do look great.
Old 02-25-2009, 02:21 AM
winter-hater club member
nynor's Avatar
you are going to convert it to early offset? get some cup 2's and call it a day.
"COOL PRIUS!" - Nobody Ever
Old 02-25-2009, 10:00 AM
yea, its easy to convert. .I hate cups, the only wheels i think suit these cars are fuchs. so in response to your statement. No
1987 944 n/a
Old 02-25-2009, 12:47 PM
nynor's Avatar
*shrug* to each their own. seems like a lot of work.
Old 02-25-2009, 12:49 PM
Feelin' Solexy
Tishabet's Avatar
+1
This is one part of the car that I would not backdate...
Grant
1974 Vespa Rally 200, 1974 Vespa Primavera 125, 1963 Solex 2200, 1938 Buick Special, 2008 Mini Cooper S, 2010 Mazda CX-9, 1986 VW Vanagon Syncro Westfalia, 1989 VW Doka Tristar - in the stable
1989 Porsche 944, 1973 VW Beetle - gone but not forgotten
Old 02-26-2009, 05:38 AM
What parts are you going to swap to change the offset?
Old 02-26-2009, 09:33 AM
Unless you are going to be running at a track a whole lot there isnt much benefit other than cosmetics. Also that car would be sex if it lost the crest on the fender. To Ferrari esque IMHO
Sidney J.
Old 02-26-2009, 10:33 AM
nynor's Avatar
is there a benefit at the track with early offset? are we talking the weight of the wheels? if so, you are better off with a lighter tire. there is more energy moment (i think is the term) the farther from the center of a spinning object.
Old 02-26-2009, 12:42 PM
this is purely cosmetic, i have a preference for fuch wheels. In 1987 porsche changed the width to better fill out the fenders with the phone dials, dont quote me on that though. Its just pillow talk. Its surprisingly easy if you have a donor car.
All thats needed is early offset hubs and brake rotors, im not replacing the wheel bearings while im down there cause when we pulled the hub they looked ok. Josh
1987 944 n/a
Old 02-26-2009, 02:24 PM
I was talking the weight/strength benefit.
Sidney J.
Old 02-26-2009, 02:42 PM
