What would Darth Vader do
Gordon Rankin's Avatar
Send a message via Yahoo to Gordon Rankin
Self honking horn problem
I had to pull the horn relay today.
The darn thing would start to honk on its own (embarrassing) randomly while going down the street and freeway.There were many short random bursts.
People were looking at me strangely. Like I had something to do with it...
Anyway, I pulled over and pulled the relay.
Anyone have a solution or idea?
1983 944 (2002 to now)
3-924's (Sold)
1967-912 (Traded)
NEVER put a used water pump in your car...
Old 11-02-2008, 10:03 PM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
try wearing a George Bush mask whilst driving the car, then people will understand why the unwarranted aggression.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear sway
Hyundai Ioniq hybrid daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 11-03-2008, 04:26 AM
Sorry, that particular "scary" mask sold out so I am unable to unleash that WMD. Maybe next year.. Oh sorry, thats right, he wont be around next year!
3-924's (Sold)
1967-912 (Traded)
Old 11-03-2008, 06:30 AM
earlr85944's Avatar
pull the steering wheel horn pad and check the wire, maybe frayed,
replace the relay,
chech the horn ring under the steering
check the nut behind the wheel (thats you), enroll in anti road rage classes
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 11-03-2008, 07:17 AM
Quality
phoenix_iii's Avatar
Ugh!
Swap the relay for the horn with the fog lights... same relay. Fixed mine. Order a new relay. Don't pull the horn pad, etc, without doing this simple test first...
85.5 944 NA 5spd - Sold but not forgotten
89 951 Turbo S - Revival in progress...
Old 11-03-2008, 08:51 AM
Earl, just exactly are you trying to tell me? I already checked the wire with the sticking the finger in the socket, tongue to the wire trick and I got shocked! That means the relay works..Right?
And I failed my last 2 anti rage classes.. Just dont work!
And which horny ring would that be?
replace the relay,
3-924's (Sold)
1967-912 (Traded)
Old 11-05-2008, 04:08 PM
Used & Abused
+1 on trading out relays before you tear apart the steering wheel.
83 - 944, daily driver
62 - VW Karmann Ghia, never moving restoration
"Oh Bother," said Pooh, as he chambered another round.
Old 11-05-2008, 04:44 PM
earlr85944's Avatar
did you swap the relay
83 944....bye bye
Old 11-06-2008, 05:08 AM
thekidd's Avatar
Send a message via AIM to thekidd
If you took the steering wheel off, or had to get behind the dash there are 3 flathead screws underneath the stering wheel. If you took these out, and didnt screw them in fully, the horn will spontaniously honk, because when you turn L/R, the horn contacts with the other contact, then honks the horn. Happened to me a few times:P
Day light saviong already happened, its 11:04AM here, but my post time says 12:04PM. Must of been the DeLorean ride last night, wheeew, what a ride, dont remember anything after I hit 88MPH?
Steve- If you havent looked, look- www.clarks-garage.com
87 951 red- Maria (current)
84 944 white- Percilla (current DD)
85.5 944 red- Pinta (past)
87 924S red- Nina (past)
Old 11-06-2008, 08:04 AM
Politically Incorrect
onZedge's Avatar
Originally Posted by Gordon Rankin View Post
...And I failed my last 2 anti rage classes.. Just dont work!...
Maybe you need to try the "forehead-to-the-wire" trick. Several times.
Edek
'87 924S
'91 535i
Old 11-06-2008, 05:57 PM
Will do Sat or Sun.. Road rage classes eating up time!
Will check in then!
3-924's (Sold)
1967-912 (Traded)
Old 11-07-2008, 09:41 PM
I will need a live demonstration to get this one right! Can you show me how its done?
3-924's (Sold)
1967-912 (Traded)
Old 11-07-2008, 09:46 PM
altf4's Avatar
This happened to me. The horn pad was loose and honk every time I took a turn or went over a bump. This became very embarrassing when someone was in the cross walk that I was trying to turn through.
DONT remove the steering wheel. The horn pad just rips off. Sit in the drivers seat, grab both sides of the pad and pull towards you. There are three brass bolts in the steering wheel. They probably just need a good tightening. They hold in plastic retainers, so don't over tighten, use ~7 Nm ect. Once tightened and the horn pad replaced, if the horn doesn't the brass pins in the horn pad might have sunk in. To fix this, shim the brass bolts with a small to raise them a little.
Old 12-04-2008, 05:16 PM
thekidd's Avatar
altf4- a year on the board and first post!?!
Welcome aboard!
Did you ever get the horn fixed Gordo?
Old 12-04-2008, 07:06 PM
My problem turned out to be a bad relay of all things. Apparently they just get old and fall apart. Put in a brand new relay and no more arbitrary horn.
I thought that when a relay went out, nothing works but was not the case.
3-924's (Sold)
1967-912 (Traded)
Old 12-04-2008, 08:16 PM
sorry, this isn't really related to the topic of fixing horns, but I'm finding the whole scene of people driving around with random horn bursts pretty funny so I have my own "trick" to tell you about.
For some reason my car sets off Toyota alarm systems. Every time I drive close by a parked Toyota at low speed its alarm goes off for about 5-6 seconds
So I can amuse young relatives by taking them for a drive through a parking lot and getting all the Toyotas to "make noise" Pretty good way to pass time with 3-4 year olds
Warren
'87 944S
"Tubes sound better"
Old 12-05-2008, 09:54 AM
Now that's funny
Old 12-05-2008, 11:07 AM
It's just hollerin' to other Porsche's. Freaky lil' 944
Old 12-08-2008, 12:06 PM
I've had the same problem happen to me where the horn will honk randomly when turning the wheel.
What I've narrowed it down to is the brush from the steering wheel horn contact was scraping the metal hub of the steering wheel mount, causing it to scrape off the paint in that area.
When the wheel was turned to where that bare area touched the copper contact it would make connection and honk the horn.
I tried re-painting the hub and bending the contact tab a little and it has worked for a little while but it is now back to scraping the hub again.
My guess is that the contact is just too worn to hold that shape. Does anyone know if this part is replaceable?
'87 944
Old 02-21-2009, 03:05 PM
You might want to try replacing that relay before messing around with the horn contacts themselves. Its a really cheap part and may save you a lot of pain in the long run. It is really questionable if that piece you are messing with is the problem and very unusual.
3-924's (Sold)
1967-912 (Traded)
Old 02-21-2009, 06:33 PM
